Battery Charger recommendations
  • 81xsproject
    • 3185
    • Fortuna, CA
    Hey all,
    I am looking to get a new charger/maintainer and wanted to see if anyone had any suggestions. Also, I saw this one from northertools and wanted to see what everyone thought about paying another $20 (DK has one for $30) for this one with the "Patented PulseMode desulphation circuitry"
    VDC Electronics Battery Maintenance Chargers are designed to both properly charge and maintain all type/size lead acid batteries, without ever overcharging, even after months of non-use. All BatteryMINDer models feature exclusive U.S. Patented PulseMode desulphation circuitry, designed to safely remove the #1 cause of early battery failure, Sulphation. Plus, all units are polarity reversal-short circuit-temperature protected. Never overcharges. Restores weak batteries. High-frequency pulses safely remove sulphate from battery's plates that prevent batteries from holding a full charge. For all batteries including gel and deep cycle. UL listed
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
  • webbcraft2150
    • Sep 2002
    • 1605
    • AUSTIN.TX
    I have used a maintainer for years and I attribute my batteries lasting 3-4 years because of them and a regular schedule of checking the water (monthly). To make things easier, I wired a 2 wire trailer connector to the posts on the battery and the leads on the maintainer. I tuck the connector under the side cover when not in use. I fabbed a bracket to hang the maintainer on the footpeg bracket, plug it in and go. The nice thing about a maintainer is it will not overcharge the battery no matter how long you leave it on, as long as the maintainer is working right. Be sure if you wire a connector to the battery that the "exposed" terminal of the connector is hooked to the ground side of the battery.
    • 81xsproject
      • 3185
      • Fortuna, CA
      hmmm, no opinions or ideas about desulphation
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
        • 7828
        If the battery is maintained, you should NOT have any sulfation. It usually occurs in batteries that are left for a month or three at a time, and NOT batteries that are used all the time. Just the maintainer should keep it from sulfating.
        Ray
        • webbcraft2150
          • Sep 2002
          • 1605
          • AUSTIN.TX
          "Desulphation" option would be a good option. While I do not know the exact process it uses, it will extend the life and "like new" output of the battery. Works good on the group of forklift batteries we have.
          • Jerry
            XS & TRUE XJ GURU
            • 3023
            • Elma, IA.
            I use a $12.95 float charger, am now on my 4th year with same battery / charger and it cranks over like new. Float charger is from Gempler's:
            They also have a fancier one for $22.65, claims to eliminate battery failure due to sulphation:
            I have a couple of the $12.95 units, use one on my garden tractor. Battery in it is even older, still kicks the tractor over fine every time.
            Jerry Fields
            '82 XJ 'Sojourn'
            '06 Concours
            My Galleries Page.
            My Blog Page.
            • lsippell
              • Sep 2003
              • 216
              • Mayflower, Arkansas
              I've been using one of the cheap Battery Tenders for about 11 months now and am real happy with it. I especially like the harness that comes with it that mounts to my battery, and the extra one that has clips so I can hook it up to one of my boys bikes when they need it.
              I almost always plug it into my XJ when I park.
              Louis
              "There is no mechanical problem so difficult that it cannot be overcome by
              brute strength and ignorance" And possibly some Mouse Milk!
              '82 XJ1100J
              LED Dir and running lights
              LED Tail/Brake lights (4) one flashing
              Modulated H/L
              PIAA Driving lights
              YICS Eliminated
              750 FD
              Yamaha Factory X-1 Fairing and Luggage
              • 81xsproject
                • 3185
                • Fortuna, CA
                I decided to go for the one with the magic desulphation powers. Maybe it will save my old bat. Won't be shocked if it doesn't. I added some water a while back and I don't recall using distilled Oh well, live and learn. Besides it came with the free XS almost three years ago.
                '81 XS1100 SH
                Sep. 12th 2015
                RIP
