Rebuild opinions wanted!!
  • pggg
    • 1609
    • NZ
    wiseco forged pistons are possibly lighter than stock pistons.
    • GNEPIG
      • Apr 2005
      • 1657
      • fl
      quote from pggg
      .. exactly, there is a reason that wiseco has been in business for a long time. thanx Patrick
      good luck Tod, i'm sure your bike will run great.
      • excess11
        • Oct 2004
        • 256
        • Rockville Md.
        If the weisco pistons are lighter than stock pistons and the theory is that the crank is balanced to the exact weight of the rods and pistons. This would also create a balance problem?????? Cranks are not balanced to the weight of the rods and pistons. The rods and pistons can weigh what ever they want as long as they are all uniform in weight. Dynamic balance is what makes up for any change in piston/rod weight. When one piston is rounding the Top Dead Center another piston is rounding bottom dead center. This cancels out any vibrations. The reason why you balance a set of pistons is to make sure all piston weights are the same so when one piston is Rounding TDC the other piston is rounding BDC so the weight of the two pistons are pulling against each other with the same force thus canceling out any vibrations. As long as the weights are the same no virbations will be created.
        Dan ( A.K.A.- MacGyver )
          Lord knows I haven't the knowledge to argue here. Doesn't anyone have a rebuttal for 'ol Macgyver??
          And GNEPIG...
          You may not remember how bad I screwed up a simple head swap....(The round piston thingies, and the round valve thingies seem to like their own personal space and don't seem to like actually MEETING!) I think I'll wait for MAXIMAN to offer to use his garage, tools, and beer to get it going for me! LOL. Anybody ready for that snowball fight in Hell??
          • GNEPIG
            • Apr 2005
            • 1657
            • fl
            .. wow, so then what your saying is those large heavy looking cast steel deformations opposite of the big end journal are just casting imperfections on the crank and we can just cut them off?
            • mro
              • 4276
              • Hayward, California
              Wonder why they always seem to be opposite to where the rods are attached.
              mro
              btw, no fly wheel on an XS so would imagine that some of what GNEPIG says has merit but not critical
              • HobbyMan
                MeatHead Idiot "GURU"
                • 1801
                • Colleyville, TX
                If the pistons were lighter, couldn't you shave off the difference on the crank counterbalance? Or is there a margin in which a weight limit is acceptable. I don't really know if that would work but it seems like it would if the crank was evenly shaved. I don't see the point of going through all that trouble when the original works well.
                BTW: you guys kill me! This post is suprisingly funny. Maby its the fact that it is midnight and I didn't sleep last night,
                Acta Non Verba
                • HobbyMan
                  • 1801
                  • Colleyville, TX
                  Forgot to say that I feel an experiment coming on. I have a bunch of small RC engines to take apart. Time to get out the old scale
                  Acta Non Verba
                  • GNEPIG
                    • Apr 2005
                    • 1657
                    • fl
                    .. no, not critical, i've ridden the before and after and the results are quite exciting, although it didnt vibrate say like an XS650, the vibration was more noticable than stock. as i said, i would'nt do it to my every day ride.
                    • excess11
                      • Oct 2004
                      • 256
                      • Rockville Md.
                      I guess it is funny to make fun of things that you do not understand. Some day when you understand phisics and dynamic balace you will see that the joke is on you and you really are clueless Those large heavy looking cast steel deformations opposite of the big end journal are there to compensate for the compression stroke of the engine. This is how you get the inertia to overcome 130psi of compression. Rod and piston weight have no effect on crank balance.
                      • mro
                        • 4276
                        I just happen to have an XS thats had the crank done. Both lightened and balanced, as well as several other mods.
                        Have not ridden it enough yet to compare vibes, as have other issues dealing with first. Responds to twisting the grip "right now" tho..........
                        mro
                        to be continued.....
                        • excess11
                          • Oct 2004
                          • 256
                          • Rockville Md.
                          Crank
                          You can send a crank out to any good machine shop and get it balanced. They don't need to know the weight of the pistons and rods to do this. They do not regrind the lobes of a crank to make up for changes in piston or rod weight. A crank is spun balanced like the tires on your car and is not ground off balance so that when you add rods and pistons to it, it is then in balance.
                            This is probably not my department, but it is my link, so I felt that I needed to say something. One thing I love about this site is that you can get so many points of view from so many walks of life around the globe. The name of the game here is respect and decency. That is what takes this site above and beyond other trash talking bike sites. People here can and often do have difference of opinions, but they should be able to express those beliefs without being belittled or called names.
                            I have emailed a question to APE racing products about this, and will post back the answer I get from them. Thanks.
                            • mikeb
                              • Apr 2005
                              • 21
                              • Joliet, IL
                              Very interesting thread. I found this article which gives a pretty good rundown on crank ballancing. There are some other good explanations out there but some get pretty technical. My opinion of the rebuild is keep it pretty much stock unless you plan on drag racing alot. These are very capable and durable engines in stock form. Unless your trying to shave a few tenths off your quarter mile time I would rather spend the money on things like paint and replating. Just my .02 Here's the link. http://www.442.com/tech/balancing.html
                              Original owner of 1980
                              Midnight Special
                              • mro
                                • 4276
                                GNEPIG, 1
                                mro
                                Well it is more important than I thought for high performance in particular. Always been a fan of balancing.
                                mro
