NGK spark Plug caps
  • Filter
  • NGK spark Plug caps
    Does anybody out there know the correct part #'s for the 2 different caps required for 78E. On the stock coil there were two different length 90 degree caps. I did the coil rebuild with 7mm wires and can't find the correct caps. I run with a radio so I would like to keep the static down as much as possible. Also a good source for them.
    78XS11E
  • #2
    I bought four of the 90 degree 5K caps from MikesXS at: (352) 540-9205. I think the part number was 23-3113 (NGK LB05F) @ $2.50 each. I used these with the stock wires.
    Bill Murrin
    Nashville, TN
    2005 DL1000 V-Strom "WOW"
    2005 FJR1300 Newest ride
    • #3
      Thanks alot I was making up an order for them anyway for some brake stuff.
      78XS11E
      • #4
        The inboard and the outboard caps are different lengths. The outboard caps are 90 degree and short. The inboard ones are about twice as tall with a 30-35 degree angle.
        HTH
        Randy
        • #5
          plug ends
          My local bike shop had an asortment. Different lengths, 90 and 45 degree angles. I went with 45s on the middle plugs and 90s on the outer.
          The only thing to look out for is the connection to the plug terminal. Some ends required a teminal cap on the plug and the others connect to the threads on the top of the plug.
          Walt
          80 XS11s - "Landshark"
          79 XS11s
          03 Valkyrie
          80 XS Midnight Special - Freebee 1
          78 Honda CB125C - Freebee 2
          81 Suzuki 850L - Freebee 3
          • #6
            Randy, on my 78E the caps are different lengths like you say but they are both at 90 degrees. Two inners are made by Denso out of Japan and the outers are not marked. I didn't change them and I doubt the PO changed them, the bike only had 6000 miles when I got it.
            Will the short ones be ok, thats all I've been able to find?
            78XS11E
            • #7
              Plug Caps
              I would think that as long as the caps are in good shape and don't short out in the rain, are long enough that they do not draw the plug wire up to tight those short caps should be fine.
              Ken/Sooke
              • #8
                From the DK catalog, fitting parameters for NGK plug caps:
                1st Letter code: Plug shape
                L=90 degree elbow
                S=Straight type
                T=Special 90..has extra cap beyond junction for gripping
                X=102 degree elbow
                V=120 degree elbow long type
                Y=120 degree elbow short type
                2nd letter code: Plug size
                B=14mm
                D=10-12mm
                Z=10,12,14mm
                3rd numeric code: resistance
                05=5 Kohm
                10=10 Kohm
                4th letter code: Adaptable plug terminal
                E=terminal nut
                F=terminal stud=T.S.
                H=12.7mm(1/2")
                5th letter code: accessory type
                H=compact type
                P=special waterproof cover
                M=rubber sheathed
                R=resistor type
                Z=recreational/anti-vibration
                6th letter code:
                A=recreational/anti-vibration
                Just some of the models available thru DK:
                NGK# DK# '02 Prices Description
                LB05F 20-51 $2.40 90 degree/14mm/5Kohm/T.S.
                VB05F 20-303 $3.30 120 deg LONG/14mm/5Kohm/T.S.
                XB05F 20-305 $3.30 102 deg/14mm/5Kohm/T.S.
                YB05F 20-307 $3.30 120 deg LONG/14mm/5Kohm/T.S.
                PS, I should probably make this a tech tip!
                • #9
                  Plug Caps
                  So as I understand it the closest to stock would be -
                  NGK# DK# Price '02 Description
                  78XS11E
