Does anyone carry extra gas on their bike? What kind of can do you use? Where do you carry it? I've only seen it done once that I can recall. I'd like to have an extra gallon or two with me, but am a little apprehensive about the where's and how's. Burl
Extra Gas?
I just use the standard red plastic cans. The 2.5 gallon fits well in one of my saddle bags.
Since my sidecar rig gets such lousy mileage I end up with three gas cans when travelling the boonies. I'm still fighting petcocks on a Standard tank I ebayed and just now gave up and ordered aftermarket ones from partsnmore.
Someday I'll fabricate a tank and hook a transfer pump to it. I've seen bikes with tanks or cans mounted on luggage racks but it seems like a bad idea to me. I prefer to have "heavy" stuff as low and close to the center of gravity as possible.
Rob -
Extra Gas?.........need tums???
You might do a search.
Can't think of the guys name right now, (think he's in Colorado) but he made an aluminum spare tank for his XS. Did a very nice job of it too. Have heard of others using outboard motor fuel tanks also.
mroComment
I found these guys on Ebay. A little pricey, but I don't think I'll find better quality. For sure it's cheaper than buying and refurbishing/painting a stock touring tank (if I could ever find one!). http://www.tourtank.com/Tourtank35.html Burl'79 XS Eleven Special
"Dirty White Boy"
"Just because you're paranoid, doesn't mean they're not watching you!"Comment
Not sure what the name is, but a friend of mine uses small fuel cans that come with camp stoves that run on unleaded gas. Small, about the size of a small thermos bottle. Of course, they don't hold a great deal of fuel, but hopefully enough to get you to the next gas station when you go "Whoops!!" after realizing you are on R when you hear the motor sputter and die.Brian
remembering the same thing!Comment
Tanks Trikerneil
yup, that's the one.
Places out here and mid west where you can go for 150 to 250 miles without seeing a fuel stop. Also here in CA there are fewer gas stations now, even though there are millions more cars on the road than when I was a kid.
mroComment
Extra gas...
I carry a 1 gal plastic jug of gas in my left side bag, but I've never had to use it. I do rotate it ocassionally by putting it in the tank when I fill up and refilling the jug. One reason is because I need the extra weight on that side to make hands free riding possible without having to lean left all the time. I usually have to switch to reserve at 135 mi and it doesn't seem to make any difference if I been long hard riding at 80 to 100 on the freeway or puttin at 50 through the canyons.
The Solvang trip was a real freeway adventure and Mason and I did the trip always over 80 for the trip and sometimes well over 100! My bike really likes the higher speeds, she just sings so sweet over 80, and stable as a rock.
Coming home in heavier traffic I did some really wild lane splitting at high speeds compared to traffic and made really good time, but scared me enough to swear off that in the future. I figure much more of that kind of riding I probably won't last very long. LOLYou can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
I wonder if a gallon or thereabouts would fit in the empty toolbox, or if I could figure out some way to make a spiffylookin' shiny tank that fits nicely where my old airbox was... it WOULD be nice to have a little extra, just in case - I'm headed on a few road trips eventually, and it seems like cheap insurance...Kristoffer
"Take apart yer carbs!"
1978 XS1100E - "The Maroon Baboon" (SOLD)
1979 XS1100 (3 of them) in the garage. Not deserving of names yet.Comment
Maximan has this set-up on his XJ
When his tank is getting low he turns on the valve from the standard 2.5 gallon tank - sold at most boat shops - and the gas not only gets to the carbs but flows back into the tank somewhat, as the 'auxillary' tank is above the standard tank; the gas guage actually starts to read higher after a few miles. All installation took was the tank, some 1/4 inch hose, a "T" fitting and valve. Works slick. Maximan also put one of those primer bulbs in-line, I think he uses it to get the gas flowing but don't know if it is necessary. You can see the primer and fuel line (line is light yellow) just above saddlebag and side cover. "T" is just behind the petcock.
Another advantage to this set-up is no fabrication needed, and aux tank is easy to remove. Don't make adding riding range any harder than it needs to be, guys. Photo taken on way to Lake Tahoe rally in '05.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
"... life is just a honky-tonk show." Cherry Poppin' Daddy StrutComment
