push starting
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    push starting
    Stopped at a friends place after work.
    Left the damn headlight on, about 1/2 hour.
    Never push started the bike before and wow! It couldn't have been any easier or smoother. Nice surprise.
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    You got lucky Dean,
    IF the battery had dropped below the 10.5 volts, then the TCI wouldn't have fired, and it would have been a much harder process, and still probably wouldn't have gotten it lit!?
    • LoHo
      • Sep 2002
      • 1342
      • Fresno, CA
      Yep, TC's right. If you try to use the starter several times and run it down too far, it won't matter how fast you get going when trying to bump it. If it seems weak when you get on, better push it right away! Been there, done that.
      On the other hand, push starting an XS down the road by yourself in riding gear is and EXCELLENT workout...
      ~LoHo~
      • xs650mike
        • 1286
        • Lake County, California
        The '79SF Advantage
        Shiny side up,
        650 Mike
        XS1100SF "Rusty", runs great, 96k miles
        XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
        Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
        • Czekus21
          • 1069
          • Keosauqua (Southeast) Iowa
          Jeeeezzz.... I wish you didn't show that pic. Now I gotta find the little rubber do-hicky for my kick starter.
          S.R.Czekus
          1-big XS patch
          1-small XS/XJ patch
          1-XS/XJ owners pin.
          Just do it !!!!!
          • xs650mike
            • 1286
            Kick lever is off a 750 triple.
            Shiny side up,
            650 Mike
            • AKMac
              • Sep 2005
              • 141
              • Utah
              I've got one of those too. It doesn't fit perfectly (the flat spot in the kick starter spline doesn't align with the one on the kick starter.) But I like it a lot more than the stock one. Also, you'll look a lot cooler trying to kick start your bike than having some guys push you down the road.
              1979 XS1100 Special (Chrome Queen)
                When I kick start my YZ250, if I don't have a decent pair of stiff soled boots on, it will sometimes give me a bruise like a stone bruise in the middle of the arch of my foot. You'll go to jump down on the kick starter, and with the compression... sometimes it doesn't move.... and that's just a single cylinder! I don't know what the compression comparison would be between it and my XJ, but how hard is it to kick over these 1100's?
                • webbcraft2150
                  • Sep 2002
                  • 1605
                  • AUSTIN.TX
                  Funny how a 11 gains about 200lbs when the battery is dead. As for kickstarters, they are all but extinct. I had Norton that would snap your leg if you stiff legged it. Not even gonna mention what a 501 Maico did to me one afternoon. Glad there extinct!!!!!
                  • xs650mike
                    • 1286
                    Being a four with small cylinders, the XS11 is an easy kick starter.
                    Shiny side up,
                    650 Mike
                    • mason79
                      • Mar 2006
                      • 1359
                      • los angeles, ca
                      did you have to modify the xs750 kickstarter to fit? and do you just leave it there and kick all the time to save the starter mechanism?
                      how does it start cold? easier than and rd400? the like the nostalgia!
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
                      • xs650mike
                        • 1286
                        Kick start drill
                        Same drill as with an electric starter. Select neutral. Prime for a minute to fill the floatbowls. Pull in the clutch and kick to free the clutchplates. (I free the clutch even when electric starting, keeps it from grinding first time it's put in gear. Old Britbike habit. Not necessary for hot start.) Let out the clutch, pull out the choke, turn on the ignition and kick. Mine usually will start first try but if not a kick or two more will start it.
                        I didn't modify the lever in any way. It was a little hard to get the pinch bolt to thread past the splines on the starter shaft, should have Dremelled a slot in it but I don't own a Dremel and am too lazy to file a slot by hand. I leave the kick lever in place since it will fold out of the way. The stock "emergency" lever that's under the battery box doesn't fold so it has to be removed after starting which is why I put the other lever on in the first place. I mostly use it when I'm in a gas station and others are watching, hee hee.
                        Shiny side up,
                        650 Mike
