I need to sort out shims ect, any idea what gaps what order ect.
Help with shims ect
Tags: None
Welcome, Crazy Pete.
I assume you're attempting a valve adjustment? I hope you have a maintenance manual? If not, do a search here for valve adjustment and you'll find the procedure.
Also, here is a link to an excel spreadsheet to help you figure out which shims you'll need after you do your measurements;
Shim Calculator -
Dang, I was looking for the spreadsheet when I did my shims last monthPat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
Pete,
IF that is the engine # then you have a 1978 model. The 2H9 is the european model of the 2H7. You can look up your serial # on the left under the heading "specifications".
That being said, the starting clearances for the 78 model are:
Intake: .16mm - .20mm
Exhaust: .21mm - .25mm
RandyComment
.. and for those of us who dont own a set of metric feeler gauges
intake: .006 - .008
exhaust: .008 - .010
..i've been meaning to get a set of metric gauges, they might be more acurate
i have not tried the calculate/formula way to adjust valves yet, it seems easer to just stick the next size shim in and remeasure until you get it right.. but hey, that other way might be fun toComment
