Intake boots at a cheap price on Amazon
  • XS11NEWROSS
    • Dec 2013
    • 48
    • New Ross, Co. Wexford, Ireland
    I paid over $120 for a set of these a few years back but came across this a few minutes ago. Not sure about quality etc., price is pretty good though in case it helps someone here, about $20. Seems very cheap!
    Paul
    https://www.amazon.co.uk/KIMISS-Plas...arb+set+xs1100
    Might just be my suspicious mind. 19 Pounds Sterling is a lot more that $20 not clear if that is for each of 4 available ? Postage to cross the pond will be a hell of a lot more than you are accustomed to with USPS
      • 735
      Notice this in the upper right hand corner of the Amazon ad:
      £18.39
      No sellers are currently delivering this item to the United States.
      • aquamantx
        • Aug 2015
        • 198
        • Montgomery, TX
        This is what I ordered and installed. Rubber looks good and only difference i see is that the 1 and 2 on the boot go to the opposite side of original. Pert fit fine and synch tube is in correct place.
        81 LH in process
        09 vstar 1300
        only allowed 2
          • 9981
          https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
          Not quite sure exactly what you said in some of that post. That is a good price.
          Some of the less expensive sets like these have had some minor issues you might want to keep an eye on.
          1; the sync ports have fallen out of some (speaking from experience).
          2; DO NOT use the paper gaskets that come with them. They fail and leak. Just a very thin coat of yamabond or equivalent works perfectly.
          • aquamantx
            • Aug 2015
            • 198
            • Montgomery, TX
            If you look at the joints they have a 1 or a 2 on the carb side. The original had the number 1 on the right and 2 on the left. These have 1 on the left and 2 on the right. It indicates what side of the engine to install on.
            81 LH in process
            09 vstar 1300
            only allowed 2
              • 9981
              Never seen anything like that. Just 2 that fit the left and 2 that fit the right.
