Muffler Removal
  • Patrick1980
    • Mar 2023
    • 42
    Muffler Removal
    I currently have the stock 2 into 1 on each side exhaust on my 1980 and I want to make it louder. I have read that it is possible to take the baffles out of the muffler. I attempted to slide the muffler off the pipes today and they would not pull out all the way. I haven't seen any forum about how to take these off. I'm not sure if I'm missing something but after about 6 inches of pulling back, it gets stuck even when hitting it with a rubber mallet.
    Thanks
  • Tonyxs11
    • Oct 2022
    • 271
    • Cumbria UK
    the OEM exhaust on the XS11 is a one piece unit, the only part that will come off is one of the headers. their also a sealed unit so baffle will not come out
    • Patrick1980
      • Mar 2023
      • 42
      I think mine may have a different after-market muffler on it then and it is just so snug that it won't slip off easily, thanks for the response, I'll keep trying.
        • 254
        HI Patrick,,,if you want to do a great upgrade to make them growl more, get a set of Harley Mufflers and attach them. THe HD mufflers sound great, are have that rumble, growl of a Harley only better. Should be lots of them avail. on craigslist or any Harley store as a lot of owners yank them after buying. DO a search here on harley muffler in the search and there is a few detailed guides to do it. YOu also can drill into the mufflers but the sound is kind of raspy.....I have done a few xs1100's with the HD mufflers, off of any dyna HD or similiar engine size and they all sounded great.....good luck, keep us informed,,,,Mike in San Diego and PA.
        • Patrick1980
          • Mar 2023
          • 42
          Ok I'll go check it out, I just went back at the mufflers on the pipes I have now and got them off... Finally. The key was to use a heat gun and they were able to barely get by. I plan on upgrading to pod filters/velocity stack setup so I was going to reject the carbs but since I was going to change the jets might as well change the exhaust and not have to reject them later on again.
            • 254
            Hi again,,,,with the HD mufflers you woount need to rejet the carbs,,,,you will lose a little at the low rpm, thats about it, with the pod filters you will lose even more as it will run leaner. There is info on the search site for jetting with pod filters, but most find its hit or miss, depending on the type of filter switch to. Just suggesting, the bike will run the best with the factory airbox, and once the carbs are cleaned and synched you wont need to touch them again for a long time,,,,,good luck, Mike in S.Diego and PA.
              • 1638
              Pat, altering the exhaust and intake in any way will seriously effect your fuel to air ratio. These bikes were delivered on the lean fringe because of early EPA regulations. It will run like crap unless you re-jet.
              • Patrick1980
                • Mar 2023
                • 42
                Thanks for the feedback, I was planning on rejecting anyways, going from 110 mains to 117.5s or 120s (gonna try both) and up to a 45 pilot possibly. I have been doing lots of research and have found the best way to run pods is to use the velocity stack rubber piece that comes into the airbox from the carb on the pods, that way the air becomes laminar and it shouldn't affect the CV carb too much.
                  • 7808
                  Niche Cycle is my go-to for genuine Mikuni parts. Jets-R-Us does well by me too.
