wheel mouse can change font size in forum
+ More Options
Posts
  • Mike Hart
    • 1025
    • Seattle, Washington
    Just saw Gary post a great tip, so I'll pass it on -
    Did you know that in IE (if you have a wheel mouse)
    you can hold down the ctrl key and roll your wheel
    and the font size will change? Awesome.
    Mike * Seattle * 82 F'n'XJ1100 *
  • chicago1010
    Hey, that helps alot
    • sixtysix
      No XS but XSive as can be!
      • 1958
      • Central New York State
      JP showed me this, there is also a non-wheel mouse solution but I am not sure wich menu it is on. JP?
      Gary Granger
        Go to the menu at top of IE, select VIEW, TEXT SIZE, then select from many choices, "Smallest, Small, Medium, Large, Largest" !
        • Mike Hart
          • 1025
          alt-v-x brings up the text size menu...
