Editing
  • KA1J
    • 664
    • Groton, CT
    Editing
    Sometimes I make mistakes in my post and some time later I realize what I meant to say was not expressed or a photo needed in sequence has to be added or a clearer one taken later inserted in its place. The edit feature here only lasts for a couple of minutes and then I can't alter what I posted.
    Is there a setting option I've missed that allows me edit ability to correct or add to my post at later dates? It helps with continuity and I'm used to being able to do that on other forums I belong to and it really helps to make an inaccurate post more clear.
    Thanks!
    Gary
    Nope, it is a set 10 minutes that you get. Nothing to change.
