This is Great (formatting text)
  • Filter
  • This is Great (formatting text)
    [COLOR=blue]This is going to great ( Good job Guys)[COLOR=crimson]
    Rick Wood
    XJ1100 (Construction Complete)(SOLD)
    Northern Michigan
  • #2
    Re: This is Great
    Rick Wood wrote
    "COLOR=blue" This is going to great ( Good job Guys)"COLOR=crimson"
    You also need to use the closing commands to make the formatting to work. Same command, with a slash in front. Like this, "color=blue" xxx "/color" (Use the square brackets instead of the quotes in my example). If you're still having trouble with formatting, try the format buttons and see what they do.
    BLUE then CRIMSON.
    Have fun and welcome aboard!
    Bill
    Bill K.
    1985 Yamaha XJ700 Maxim
    1986 Yamaha FZX700 Fazer
    • #3
      Test Test[/COLOR]
      Rick Wood
      Northern Michigan
      • #4
        Testing
        I THINK I HAVE IT
        Rick Wood
        Northern Michigan
        • #5
          Are the brackets ( [ ] ) used in Vb code instead of < > for html? Are the commands within the brackets the same or similar to html?
          Tests below:
          this is only a test
          another one
          yet another one
          80sg "Reaper"
          • #6
            Yet another one
            [p] [big]
            yada yada[/big]
            [p]
            ETT
            80sg "Reaper"
            • #7
              Well, some similarities, some not so...
              80sg "Reaper"
              • #8
                Capocrimini wrote:
                [QUOTE]Yet another one...[big]
                The SIZE= is used in vB code. 2 is the default here; 1 is smaller; 3 & 4 are bigger.
                For colors, you can click on the color menu to see the standard colors or use HTML hex codes (#xxxxxx) for colors not offered on the menu. I usually stick with the standard ones because the show up well.
                Bill
                Bill K.
                • #9
                  Well Thank you Very Much
                  80sg "Reaper"
                  • #10
                    Ok Like this?
                    I see just click "x Close all Tags" and its done.
                    [b][size=4][font=times][color=#BD0062]Wayne[/color][/font][/size][/b]
                    [b][size=4][font=times][color=#095de5]TeXSive forever[/color][/font][/size][/b]
                    The best alarm clock is sunshine on chrome.
