photo test
    • 8938
    photo test
    • 8938
      • 8938
      • dbbrian
        • May 2016
        • 596
        • Stratford, Ontario, Canada
          • 8938
          Provides free image uploading and hosting integration for forums. Free picture hosting and photo sharing for websites and blogs.
              • 8938
                • 8938
                Ick, ethanol...
                  Ick, ethanol...
                  That's a great picture, it almost looks a slice of veggie-parmesan lasagna....
                    • 8938
                    Irma is coming by for a visit...
                      • 2162
                      ...and I thought that was your avatar, Phil!
                      Stay safe.
                      • Chuckster
                        • 93
                        • Crystal Lake, IL
                        Chuckster
                        '78 XS1100E
                        Money can't buy happiness, but it can get you an XS11 and that's a start.
                        • dbbrian
                          • May 2016
                          • 596
                          trying to post a pic
                          I give up
                            • 8938
                            Brian, copy the image address and place it between img brackets.
                            Example...
                            [img]your image address[/img]
                            And here it is after doing that...
                            • TruthHammer
                              • Jun 2017
                              • 65
                              • Carmel, IN
                              If the "put it between tags" direction isn't totally clear, try hitting the quote button under one of the posts that had a picture. You'll see exactly how it's coded. Also, if you're using a site like imgur, make sure you're using the path to the image file itself, not a web page that contains it.
                              SF / SH Frankenbike
                              • SF - frame, carbs
                              • SH - engine
                              • TBD - everything else
