test
test
'80 XS1100 SG
https://www.youtube.com/watch?v=x_Z4cjUlIo4Tags: None
1-2-3
I don't know, but it looks like your test was disasterIf you go to the Main Forum Page and scroll down there is a area just for testing.
'81 XS1100 SH
Sep. 12th 2015
RIP
Click on pic and the test came thru,just fiddling around a little, don't know if the right forum tho...if not just delete MR. Mod...slowly learning so I can post some ride pics.'80 XS1100 SG
81 thanks,on my computer I can see the pics but you must have the infamous white box with the little red squares...I have the directions right in front of me,will try again tomorrow nite..gotta call it quits,work tomorrow.'80 XS1100 SG
Using Photobucket,TC talked me thru this once before and I printed the instructions and did it right...will try in the proper forum tomorrow nite,thanks,gotta get:-('80 XS1100 SG
The address you supplied to use inside the img tags was to the entire slideshow at photobucket. You want to select an individual photo, then use the address just for the photo, inside the img tags. Should look like this:
You can hit the quote button for this reply to see the syntax of the section that displays the image.Ken Talbot
'80 XS1100 SG
Not what I had in mind, will try again later.....I am getting closer at your expense..thanks for moving this to the correct forum...Bill'80 XS1100 SG
When you're looking at your photobucket page, click on the thumbnail first so the photo you're after is displayed in its full size. Hover your mouse over the photo, right click to see the photo's properties. "Cntrl C" to copy that address into your clipboard. Move back to the forum page. Click on the IMG button. "Cntrl V" to paste the address into the approprioate box. Hit enter and you should be good to go.Ken Talbot
'80 XS1100 SG
'80 XS1100 SG
Sorry about dbl post,my fault,did the picture go thru? On my end I got it but are you able to see it? Thanks,Bill'80 XS1100 SG
