Seat Bolts & Long Heavy Nut Set Anyone?
  • MarkD
    • Jun 2013
    • 488
    • N. Michigan
    I am looking for the bolts ( I have one) that go through the seat bracket, and the (14mm?) heavy nuts set. Not sure if all seats use same bolt/nut set, but have 79F. Thanks--Mark D.
    79 F
    1967 Suzuki X6 Hustler
    1973 Suzuki TM 125
    1979 XS1100 F
    2005 Kaw. Vulcan VN800
    1991 BMW K75
  • Old Red
    • Jul 2012
    • 290
    • Greenville, NC
    I think I have an extra one. I will check tomorrow and see, it so you are welcome to it.
    The Other Earl
    80SG, 81SH, 80 standard parts bike, 81SH parts bike
    and new to me 78 standard dresser
      If someone has one that is great. I basically made one for one of my seats. I took a piece of 16 gauge metal and cut the plate that goes under the bracket that bolts to the seat. Really just a piece with the sides folded up, almost the same length as the bracket is wide. Drill a hole in the center and use some JB weld to cement your bolt in place. You can buy the long nut at most decent hardware stores.
      • MarkD
        • Jun 2013
        • 488
        • N. Michigan
        O. Red-- sounds good, DG, I sort of got my seat on using an idea similar to yours, but I guess I want the regular equipment if available. Something about OEM stuff, I guess, even though my mufflers will never qualify.
        79 F
        1973 Suzuki TM 125
        1979 XS1100 F
        1991 BMW K75
        • Old Red
          • Jul 2012
          • 290
          • Greenville, NC
          Hi Mark,
          I have the bolt and nut you need. PM me your mailing address and I will pass it along your way.
          The Other Earl
          • Old Red
            • Jul 2012
            • 290
            • Greenville, NC
            I put it in the mail this morning and it should get to you by the first of next week.
            The Other Earl
            • MarkD
              • Jun 2013
              • 488
              • N. Michigan
              Thanks, Earl, I appreciate it. ( PM sent, too)
              79 F
              1973 Suzuki TM 125
              1979 XS1100 F
              1991 BMW K75
              • MarkD
                • Jun 2013
                • 488
                • N. Michigan
                Thanks to The Other Earl, I now need only just one of the (14mm) heavy nuts. I will be set then. Thanks--
                79 F
                1973 Suzuki TM 125
                1979 XS1100 F
                1991 BMW K75
                • MarkD
                  • Jun 2013
                  • 488
                  • N. Michigan
                  Just a bump to see if there's one more 14mm seat nut out there, thanks.
                  79 F
                  1973 Suzuki TM 125
                  1979 XS1100 F
                  1991 BMW K75
