like title says": 125.00 shipped this is good replacement. heavy duty fuselinks done right. fuse box was removed. just wires and fuses now.
78 std. wire harness
Tags: None
check out other parts pm me if you see any thing you interested. will be adding other parts soon.
79 xs 1100 spec & 80 xs 1100 g -
do you know if this would fit on a 1980?Barry Kustes. Call me BEAR
Luggage rack
Sissy bar
Open header
Work in progress
Daily riderComment
There are a lot of differences between a 78 harness and an 80 harness. All of the signal and lighting switched are different, as are the brake lights. I know that even the fuse box connections and TCI connections and location are different on the 80 than on the 78 as well. You would either have to do major surgery on the bike, or on the harness to make it work, and it would likely be less work to just fix your harness unless yours was extremely cut up.Cy
