1979 XS1100 Special - Beautiful - Make Offer
  • AKMac
    • Sep 2005
    • 141
    • Utah
    Hey guys, I've tried selling my bike a few times over the years, but I think the time has finally came. I don't have the motivation and I need to make room.
    The bike was running a year ago just fine. The speedometer went out on it and I had a GPS speedometer replacement made with the original faces to match so that it looks OEM. The will install into the OEM chrome housing as well (I have a set of new housing so it will look slick.) I had them program the original mileage into the speedo which is around 27k. I still have the original speedo and tach. The only thing that is needed is to wire them in. They cost me $600.
    I also have another engine for the bike. As I recall it has around 20k miles on it with good compression on all cylinders. The idea was to do a 2nd gear fix, powder coat it black, and install it. As you can see I never got around to it. It cost me around $400.
    The bike runs just fine (although the carbs may be dirty from sitting a year, I did run stabilizer through it). The 2nd gear just jump if you get on it, so that will have to be addressed at some point. But really, all it needs is the gauges installed and the 2nd gear fix. Most everything else on the bike I have gone through at some point.
    I'm not looking to make a killing on it. I'm more concerned it goes to someone who will take care of it and use it. I could probably make a lot more money parting it out, but I would rather see someone use it. If no one is interested I will probably be forced to part it out.
    Send me you offer.
    Things I've done to her:
    - Replaced front and rear wheel bearings and seals
    - Installed EBC pro-lite full floater rotors
    - replaced front master cylinder
    - Spiegler stainless steel brake lines with chrome fittings
    - Rebuilt calipers and installed new bleeders
    - Polished lower fork tubes
    - Installed progressive front springs and changed fork oil
    - Installed T-kat fork brace and had it chrome plated
    - Chrome plated front and rear wheels
    - Chrome plated triple tree
    - Chrome plated Speedo/Tack bracket
    - Chrome plated clutch and brake levers
    - Chrome plated valve cover
    - Chrome plated all four engine side covers
    - Chrome plated rear brake lever
    - Chrome plated side stand and center stand
    - Chrome plated exhaust hanger brackets
    - Replaced gear shifter lever
    - Replaced all four blinkers and bushings
    - Superbike bars
    - Installed Mikexs 650 chrome plated control switch housings
    - Kuryakyn mirrors
    - Kuryakyn ISO grips
    - Replaced gas cap with one from Mikesxs and swapped guts so I could use my old key
    - Tank and side covers painted with Burnt Metallic Orange with pearl ghost flames
    - Custom "Yamaha" and "XS Eleven Special" emblems
    - MAC 4-into-1 exhaust system
    - Replace rubber foot rests
    - Replaced OEM fuse box
    - Installed XS 750 kick starter and had it chrome plated
    - Replaced King and Queen seat with OEM seat
    - Replace rear suspension with Progressive 412 Standard Series Shocks
    Spare Engine
    1979 XS1100 Special (Chrome Queen)
    Could be wrong, but if IRC you hauled all those parts in the back of a Honda car to be chromed here in Grand Junction. Correct me if I'm wrong.
      • 3956
      She's a beauty!
        • 2098
        Super nice !!!
        I'd throw out the living room sofa to make a spot for Her
        Great job !!!
        • LVTom
          • May 2007
          • 85
          • Las Vegas, Nevada
          Specia
          PM sent to your mailbox
          Tom
          • AKMac
            • Sep 2005
            • 141
            • Utah
            PM Replied to...
            motoman - That is a good memory you have. It wasn't a honda, more like a clapped out 1995 Chevy Lumina, but yes I did drive down to Grand Junction for the chrome. I actually tried contacting the same company a couple years ago when I chromed the starter cover and the bearing cover next to it, but it appeared that they went out of business?
              Sorry I couldn't remember the type vehicle everything was hauled in. I just remember all those pics you posted with everything literally stuffed in the back of it! Definitely an ambitious effort made. I seem to remember the reason for hauling everything down here to G.Junction was there was nowhere in Salt Lake at the time that chromed alum./magnesium alloy. But hey..... if I remember that was some ten yrs. ago...or there-abouts.. Remember the build process and pis well! That'll sure make someone an eye-catching ride!
              • SteveO
                • Aug 2002
                • 91
                • New Jersey
                Beautiful!!! Makes my 79' look a little dingy, but that's ok. Who ever buys it will have a sweet looking bike! (Pretty sure the King & Queen seat was a Yamaha option, so technically it would have been original too).
                Good Luck.
                1979 XS1100 Special - On the Road https://xs11.club/core/images/smilies/smile.png
                1973 RD350 - In the Shed https://xs11.club/core/images/smilies/frown.png
                • AKMac
                  • Sep 2005
                  • 141
                  • Utah
                  No offers yet, still available.
                    • 6764
                    Its winter....Spring should be a better time to sell...
                    2005 Honda SilverWing 600
                    2018 Honda PC-Xpress 150
                    • AKMac
                      • Sep 2005
                      • 141
                      • Utah
                      Bump Bump Bump
                      • AKMac
                        • Sep 2005
                        • 141
                        • Utah
                        Bike has sold, thank you
                          • 8062
                          Where did you send that beautiful beast?
                          • AKMac
                            • Sep 2005
                            • 141
                            • Utah
                            About 5 miles from my house ironically.
                            If anyone is interested, I have a ton of spare parts that I will be listing here before ebay. Keep an eye out.
                            • AKMac
                              • Sep 2005
                              • 141
                              • Utah
                              All my spare parts listed here:
