'79 XS1100SF Aynor SC
1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
Mike -
this is a triple tree from a standard
this is a triple tree from a special
the standard forks have the axle at the bottom of the fork, whereas the special forks hold the front axle in front of the forks. which is why the standard trees have more rake. and if you try to put a standard tank on a bike with special trees, the trees with hit the tank when the bars are turned all the way.
somehow, i think you are looking for a more technical answer.
Steven
1981 XS 1100 LH
1979 XS 1100 SFComment
I had Special forks in Standard trees for a while, the front wheel sticks out a bit further. Handling was shaky at 75MPH.
☮Comment
Triple Tree
It appears that this bike (with the Standard forks) still has the Special triple tree. Am I seeing that right?
Mike1981 XS1100H Venturer
K&N Air Filter
ACCT
EBC Front Rotors
MikeComment
The above bike is a 79 Special with standard forks in the Special TT's. Yes Mike you are seeing it right.
☮Comment
K&N Air Filter
ACCT
EBC Front Rotors
MikeComment
Or, the guy just had a pair of standard forks and knew they'd go on with no issues, lol.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
