1982 XJ1100 Maxim Ebay (not mine)
1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
Interesting re-positioning of the rear footrestsTom
1982 XJ1100, waiting resto to originalComment
A-1 Edition
Did a little searching right after I posted the link; couldn't find any mention anywhere of the "A-1 Edition" Maxim -- Strange
Hopefully one of the more knowledgeable members (c'mon Gurus!) can chime in and let us all know...Last edited by Prisoner6; 12-16-2013, 12:53 PM.Marco
1979 Honda CBX
2002 Kawasaki ZRX1200R
WE MISS YOU, DONComment
78 XS750Comment
I have mine re-positioned the same on my Venturer. Used a cut to length piece of stainless pipe for spacer in the aluminum recess. Gives additional leg room for passenger without legs being tucked under and calfs riding up against the luggage frame-work.
As for the A-1 thing...........definitely meant to be A-1 condition, not edition
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
no Its the badge someone put on the front nameplate...definitely not A1 condition...look at the pics...I have mine re-positioned the same on my Venturer. Used a cut to length piece of stainless pipe for spacer in the aluminum recess. Gives additional leg room for passenger without legs being tucked under and calfs riding up against the luggage frame-work.
[QUOTE=madmax-im;428538]no Its the badge someone put on the front nameplate...definitely not A1 condition...look at the pics...
[/QUOTE
Apparently an A-1 bike to someone at some point in time......
Never heard of an A-1 edition XJ, and I have been on the list for 14 years. There is some trouble with the tank paint and tail light lens but everything else looks clean. Problem with speedo can sometimes be traced to too-long screws which drag on the gears causing premature failure. Can be fixed. Price is under $500.00, not bad if the rest of the mechanicals are good and there is a clear title.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
"... life is just a honky-tonk show." Cherry Poppin' Daddy StrutComment
My wife is 5' 2" and had the same problem, I made some risers to lift the rests up but mounted them on the original position. Your seat is quite a lot higher than standard which would make the original rear rests further away, I bet your missus was well comfy with the comfy seat and forward rests, like sitting in an armchair.
Knowing you lads' bikes have more forward front rests than Euro bikes, I originally thought the ebay bike's rear rests may have been brought forward for the rider to tuck his legs into.Tom
Yes the raised/forward position of my passenger pegs is better for any size passenger 'cause they can hold themselves back during braking.
The seat is a Travelcade kit that replaces both vinyl and foam but is really dense foam.
With the weight of the fairing, hard bags and trunk, and also the load that will be in them, I need to lower the seat 1 1/2", both driver and passenger, so that the passenger will sit down in more and so I can stand flat footed at red lights.
The grab bars are JIC but with the wrap around back rest she doesn't even have to hold on. Both were adapted from the HD Ultra Classic.1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
[QUOTE=motoman;428545]There's something about this one I really like. It would be really cool to see someone here with the knowledge and skills restore this one to it's former glory!!
Marco
1979 Honda CBX
