Carb parts
  • Aches n Pains
    • 349
    • Reston, Va.
    Carb parts
    Hi guys,
    Restoring an old set of carbs for a friend and he's short a few parts.
    1978 E
    Need one Diaphragm Assembly (slide, diaphragm and needle)
    Need all three plates that bolt to the caps and help hold the carbs together (look like butterflies with four holes) including the one with drop down for the throttle cable
    I have a slide and diaphragm from an XS650 (thanks, Donebysunday) but would need the correct needle. Also not sure about the slide as it has two holes in the bottom (one is not open below the slide) and I'm not sure if that effects performance.
    Thanks in advance for any help you can give,
    Aches n Pains
    Doug
    1995 KZ100P
    Pods, jets, pipes, cam adjuster, oil cooler
    1977 Ironhead - custom build
    Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
    Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
    • 7837
    Doug,
    I'll check my parts but I think I have most of what you need. I'll PM you either Tuesday or Wednesday, depending on the "honey do" list and my time.
      • 7837
      Doug, sent you a PM. I do have the parts, you can have them for shipping cost. The only thing I'm NOT positive about is the needle, as it may be a '79.
