79 special front fork cover emblem reflectors
  • Blank Slate
    • Nov 2013
    • 392
    • Ottawa, Ontario, Canada
    See the ad on ebay, that's exactly what I'm looking for but with less rust
    http://www.ebay.ca/itm/1979-Yamaha-X...p=mtr#shpCntId
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
  • Blank Slate
    • Nov 2013
    • 392
    BUMP
    Front fork cover + emblem + reflectors
    3H3-23122-00-00 GUIDE, COVER UNDER
    2M0-23395-00-00 EMBLEM
    2N8-85111-00-00 REFLECTOR (355-85111-00)
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
    • Rasputin
      • 3192
      • Lacombe, Alberta, Canada
      Expand your search a bit. I used XS part number finder and entered your part number 3H3-23122-00-00 GUIDE, COVER UNDER, and it came back with this result.
      36 similar parts are
      10M-23122-00-00 [View Photograph] Cover, Outer 1 XJ1100J
      1T3-23122-50-00 Cover,outer 1 XS650D
      1T3-23122-51-00 Cover.outer 1 XS6502F, XS650E, XS650F, XS650G
      2G2-23122-00-00 Guide, Cover Under XS750SE, XS750SE-311211, XS750SF
      2H7-23122-00-00 [View Photograph] Cover, Outer Left XS11002H9, XS11003X0, XS1100E, XS1100F, XS1100G, XS1100H
      2M0-23122-00-00 [View Photograph] Cover, Fork XS650SG
      3H3-23122-00-00 [View Photograph] Guide, Cover Under XS1100SF
      3J2-23122-00-00 [View Photograph] Cover, Outer 1 XS850SG, XS850SH
      3J6-23122-00-00 [View Photograph] Cover, Outer 1 XS1100SG, XS1100SH
      447-23122-52-00 Cover.outer 1 XS650B, XS650C
      4E4-23122-00-00 Cover,outer 1 XS650H, XS650SE, XS650SF, XS650SG, XS650SH, XS650SJ, XS650SK
      4H1-23122-00-00 Cover, Outer 1 XS850LG, XS850LH
      4H3-23122-00-00 [View Photograph] Cover, Outer 1 XS1100LG, XS1100LH
      5K7-23122-00-5R Cover, Outer 1 XS11005K7, XS1100RH
      I also use another source which is boats net or some such that shows other parts that will work. I just do not have that link handy to post. Good luck.
      2-79 XS1100 SF
      2-78 XS1100 E Best bike Ever
        • 2106
        I couldn't find good fork covers either.
        Two of mine (one on the XS750 and one on the XS11) are eBay purchases from XS850s. The XS850 didn't have the reflectors. I carefully located and drilled the holes, then bonded a nut to the inside. It is so close to the correct part you would never know.
        There seem be more 850 fork covers in good shape. One of the ones I purchased was actually NOS (not this one):
        Good luck!
        • Blank Slate
          • Nov 2013
          • 392
          Thanks for the excellent info guys!
          Frame: 79 XS1100S
          Engine: 81 XS1100S
          Carbs: 78-79 BS34
          Gf bike: 78 XS650S
          Carbs: 70-79 BS38
          • Blank Slate
            • Nov 2013
            • 392
            Possible fit
            Frame: 79 XS1100S
            Engine: 81 XS1100S
            Carbs: 78-79 BS34
            Gf bike: 78 XS650S
            Carbs: 70-79 BS38
            • Cobia
              • Jul 2007
              • 1587
              • Palm Beach County, Fl
              I have one
              Hi Blank Slate,
              I have one of those in very good shape, but it doesn't have the reflector holes/bolts/mounts. I'm willing to let it go for a reasonable price.
              I'll look for it and let you know tomorrow.
              1980G Standard, Restored
              Kerker 4 - 1
              850 Rear End Mod
              Automatic CCT
              1980GH Special, Restored
              '82 XJ1100 (Sold)
              • Blank Slate
                • Nov 2013
                • 392
                Originally posted by Cobia
                Hi Blank Slate,
                I bought the one on ebay in the post above yours, it's for a xs650. it does have reflector holes but no reflectors. if it doesn't fit on my bike I will PM you for your piece. what bike did your cover come from?
                Frame: 79 XS1100S
                Engine: 81 XS1100S
                Carbs: 78-79 BS34
                Gf bike: 78 XS650S
                Carbs: 70-79 BS38
                  • 8032
                  XS650 forks are 35 mm. XS1100 forks are 37 mm. I'll be a bit surprised if it fits.
                  • Blank Slate
                    • Nov 2013
                    • 392
                    Noooooooo
                    The message you have entered is too short. Please lengthen your message to at least 10 characters.
                    o
                    Frame: 79 XS1100S
                    Engine: 81 XS1100S
                    Carbs: 78-79 BS34
                    Gf bike: 78 XS650S
                    Carbs: 70-79 BS38
                      • 8846
                      I've made one from a smaller XS fit, you need to enlarge the holes for the fork tubes and the center to center spacing is different, so it may need some bending/massaging. It will look good and you won't be able to tell the difference if done correctly. I also had to heat up the plastic emblem to give it a slight curve.
                      • Blank Slate
                        • Nov 2013
                        • 392
                        Thanks Phil. I'll keep that in mind when I take 'em to Mack's place.
                        Frame: 79 XS1100S
                        Engine: 81 XS1100S
                        Carbs: 78-79 BS34
                        Gf bike: 78 XS650S
                        Carbs: 70-79 BS38
                        • Blank Slate
                          • Nov 2013
                          • 392
                          Bump
                          still looking for this part. the one on ebay was too small like jetmc predicted. and I really don't trust my metal bending skills to warp it from 35 to 37 mm.
                          sent pm to andreas as well.
                          Frame: 79 XS1100S
                          Engine: 81 XS1100S
                          Carbs: 78-79 BS34
                          Gf bike: 78 XS650S
                          Carbs: 70-79 BS38
