Choke plunger
  • Choke plunger
    Want to buy a choke plunger for a 1980 G carb
    Vetterized 80 G 119k miles
    plunger
    PM me. I have a bunch here, there are two different sizes.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
      choke plunger
      Thank you very much Mack! It arrived last Friday.
      I've been having a heck of a time getting my carbs clean enough, still getting popping from left exhaust (carb #1 or #2). I think it"s the gallery between the pilot jet and the the three little holes at the butterfly that's not 100%. Do you fish something through there or rely on carb spray and compressed air?
      Thanks again for your help, I need all I can get.
      You're a good man
        Sorry
        I've been busy lately and didn't see your question. To clean those little holes you need to go in from the diaphram side. Pull the top, then the diaphram out. Now retract the enrichement plungers so the hole joining the diaphram chamber and enrichement plunger cavity is wide open. If you look into that hole with a flashlight tilted slightly down and to the left you'll see another passage leading down to the top of the carb barrel. Spray lots of cleaner in there then close the enrichement plungers. Let it sit for a few minutes the roll the carb body over and blow compressed air up through the pilot tower. If you put your finger under those little holes you should feel the carb cleaner coming out with the compressed air. Repeat until it blows clear.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
