I am looking for an oil pan for a 79 SF. Picked up an engine, oil plug is stripped out. Thanks!!
79 SF Oil Pan
There are thread re-placements that are not the typical heli coil, forget what they are called. Drill and tap the original and install these. May need to get a larger drain plug, I've not used these in this application so not 100% on use. I get them at Ace. Think I have a few extras I won't be needing, you will still need the tap and homemade install tool (big screwdriver), glad to send your way.76 XS650 C ROADSTER
80 XS650 G Special II
https://ibb.co/album/icbGgF
80 XS 1100 SG
81 XS 1100LH/SH DARKHORSE
https://tinyurl.com/k6nzvtw
AKA; Don'e, UD, Unca Don'e -
Hi Done,There are thread re-placements that are not the typical heli coil, forget what they are called. Drill and tap the original and install these. May need to get a larger drain plug, I've not used these in this application so not 100% on use. I get them at Ace. Think I have a few extras I won't be needing, you will still need the tap and homemade install tool (big screwdriver), glad to send your way.
Do you have a picture or link to this threaded insert of which you speak? I need to do my rear drain plug.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
