Going through the troubleshooting process for high idle, inconsistent, backfiring after recent work on the carbs.
I was told it would likely be the "octopus" which needs to be replaced.
(I'm thinking it is more likely just one of many possible problems)
If anyone has one I could sure use it.
I'm not having a lot of luck finding one.
Well, actually I am, it's just all BAD luck.
The lack of that valve will do no harm except if you leave your petcocks on, and the float valves in your carbs are not properly sealing. Even then, it will cause you to find a puddle of fuel by your bike.
