counter shaft bolt
  • counter shaft bolt
    mine is completely stripped fell out when i took the clutch basket out need one asap or info on where to get one
    Nevermind the bolt, how about the threads in the shaft???? Is it stripped, too???
      no the threads seem to be fine
        Randy, those threads are HARD. I thought I would be slick and chase the threads on mine with a tap, and it screwed up the tap. When I tried to back it out, the tap broke, so I drove it on through with a punch. The busted part of the tap shattered and the threads were still ok. I think Yamaha machined the shaft, then heat treated it, and surface ground the outer diameter.
        Also, I have looked and looked at this thing and I see no reason that a standard grade 10.9 bolt wouldn't work with a nice thick machined washer of the right diameter. Since I am on my last bolt, that is my plan next time.
        Ich habe dich nicht gefragt.
          Hmmmm.. I guess I'm just unlucky then. When mine backed out, it wallowed out and ruined about half a bolt length worth of the shaft's threads while the clutch gear ate on the bolt head.
          I went and got a couple regular metric bolts with the same threads and ran those in there and out a couple times, then installed another proper bolt. With the threads as mucked up as they were, that has been working better than any lock-tite ever could on that bolt! lol.
