Rear Master Cylinder
  • Rear Master Cylinder
    Does anyone have a rear master brake cylinder? Please PM me with a price. Thanks in advance. Tim
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
    pm sent.....
    '80 XS 1100 Standard
      Looks like we both need one.
      The one I was going to sell you is froze up.
      And the one on my bike sucks air when you press the brake pedal.
      So that makes 2 of us looking for a master cylinder.
      Maybe someone can rebuild these for us? But I dont know how
        Have you found a rear master cylinder yet?
        BDF Special
          Nope i dont think either of us have
            I believe the rebuild kits can be had at Parts N more. Typically, they just need to be cleaned. the rear is a PITA to bleed the air out of though, so it would not shock me if you need to bleed it. I have succumbed to the vacuum pump for the rear MC.
              I know mines bad... you can hear a sucking sound when you press down the brake lever. It starts to bleed but is very slow and never gets a good squirt out, just a dribble.
                Definitely just rebuild it. The rebuild kit is available at PartsNMore for $22 - P/N: 08-0216. Super simple fix. Just be sure to "Bench Bleed" it before putting it back on the bike.
                Just be glad you don't have the '81 MNS with a bad rear MC. That kit is made of unobtainium.
