#1 carb body 80-81
  • Crazcnuk
    • Aug 2006
    • 2980
    • Hinton, AB, Canada
    #1 carb body 80-81
    I need a #1 carb body (the one with the choke lever on it) for a 3U9 (1980-81 Special) set of carbs.
    Just need the body, I have everything else.
    '05 ST1300
  • Crazcnuk
    • Aug 2006
    • 2980
    Still need one of these.
    Now I have a '79 #1 to trade though!
    '05 ST1300
    • bnklin
      • May 2009
      • 8
      • Milton,PA
      Carbs
      I am new to this rebuilding carbs. I need a ? #3. third carb in from the choke. I split the aluminum trying to remove the jet. do you know were I can get one or is it reccomended to replace all 4.
      79 xs1100 special
      • Crazcnuk
        • Aug 2006
        • 2980
        You can get a single carb, but you need to make sure it's the same series. There are 2 main types for the xs11, 78-79, and 80-81.
        I need a #1 for an 80-81 set.
        '05 ST1300
        • bnklin
          • May 2009
          • 8
          • Milton,PA
          are the carbs numbured from the choke out, and if so can a #2 be used as a #3. I am assumeing #1 and #4 need to stay in there position.
          79 xs1100 special
            • 8083
            You may broaden your search to XS650 for the same year. The carburetor bodies are the same. I just replaced my #4 with a carburetor from a XS650.
            • Crazcnuk
              • Aug 2006
              • 2980
              Yes, choke side is 1, then 2-4.
              There are left and right carbs, 1 and 3 have the fuel inlet on thier right sidem, and 2 and 4 are opposite.
              I would assume that 1 is unique, due to the chaoke mount. But 2 and 4 are probably the same, although you would have to muck around with the linkages. This would make 3 unique as well.
              '05 ST1300
              • Crazcnuk
                • Aug 2006
                • 2980
                still looking
                '05 ST1300
                • bnklin
                  • May 2009
                  • 8
                  • Milton,PA
                  Yes, i am still looking
                  79 xs1100 special
