Leaky Front Master Cylinder and Need New Final drive fill bolt
    replied
    Carry one of these in my smaller tool pouch, you're not going to rebuild an engine with it but it's a great little measuring tool.
    https://www.harborfreight.com/6-in-u...per-63664.html
    Leave a comment:
    replied
    I used to run just 1 brake line to the front, but the bike is too heavy and really needs 2 working brake calipers to stoip it. Switched back to stock 2 years ago and could not be more happy.
    Leave a comment:
    replied
    Well, that's not the success story I'm sure we all hoped to hear... (⊙_ʖ⊙)
    SOooo, went back into my own personal XS1100 inventory to pull out not one, but BOTH of my "Standard" MC's and resevoirs.
    Why do I have standard's parts when I own a Special? Answer- I don't say NO to XS1100 parts boxes... ʅ(́◡◝)ʃ
    Popped off the resevoir and removed the OEM O-ring. Definitely not as "girthy" as the 3.5 mm O-ring I bought/used to replace the OEM in my Special. ໒( ⊡ _ ⊡ )७
    By my digital caliper the Standard O-ring wasn't 3.5 mm but close to 2.5 mm.
    Me being me? I put in one of the extra O-rings ( 5-in-a-pack) in the Standard groove after lubing it with Dot3.
    Then tried pushing the OEM Standard Resevoir back where it came from.
    It didn't WANNA go in with normal hand pressure and twisting/turning. (︶︹︺)
    But placing the resevoir on a flat bench upside down and twisting/pushing down MANLY-LIKE on the inverted Standard MC? (O_o)7
    ....POP! And in it went. (^_^)
    A tight fit with a lot mOaR pressure seal on the surfaces.
    Looks like the same O-ring I used for my Special resevoir can PoSsIbLy be used for a Standard.
    But it IS quite clear that the OEM Standard Resevoir O-ring isn't as "Girthy" as the OEM O-rings for the Specials. (  ゚ ,_ゝ゚)
    The call goes out cross the inter-web airways.....(´・_・`)
    "Who has replaced the O-ring in your Standard MC Resevoir and what O-ring did YOU use?" (人´∀`*)
    Leave a comment:
    replied
    Hopefully the one you found is a bit tighter fit. Who knows if the one that was in there was the correct size to begin with.
    Leave a comment:
  • Ccitis
    replied
    Local auto store had the one, although it is Nitrile. Have to hope that is fine, he sure seemed to think it was.
    Leave a comment:
  • Ccitis
    replied
    I will take it to a store to find one. Just found it odd, why would it be different. And why would cleaning it up not work...it is still so pliable. Anyways, frustrating! And now off the road.
    Leave a comment:
    replied
    That sucks. Perhaps you could measure it with a vernier.
    Leave a comment:
  • Ccitis
    replied
    Alright folks, I was all excited to get my o rings... pulled the reservoir off... man what a mess. However the 39.7mm x 3.5mm O ring I bought is not a fit. It is smaller, and a thicker O ring than what is there ( I am sure the stock one). Bummer. So what O ring do I need? I tried to clean the old one, which was still very pliable and seemed fine, but after trying again it was still weeping terribly. Thats odd to me, not sure why after cleaning it up it does not work. You can see the original O ring in the slot, and the new EPDM one I ordered (specified in this thread) that does not fit in my hand.
    Leave a comment:
    replied
    That 3D print stuff is amazing. It's like the Replicator on the Enterprise.
    Leave a comment:
    replied
    Iffin' you haven't yet pulled off the resevoir and got your own "eyes-on" experience? (O_o)
    Mebbe wurth watching.... ¯\_(ツ)_/¯
    Leave a comment:
    replied
    I'm sure EPDM will work. However, I have had a Nitrile O-ring in my KZ rear master cylinder for several years and it has not deteriorated. This is a bike that actually gets ridden under the worst conditions. It's not a coffee table bike.
    Leave a comment:
    replied
    Brake fluid is NOT oil based, so EPDM should work with no problems for years. Gasoline and motor oil is what will take out the product.
    Leave a comment:
    replied
    I've had one EPDM in service for 14 years, no problem.
    The next EPDM is 9 years with no problem.
    There are two younger ones with no problems.
    Leave a comment:
  • Ccitis
    replied
    Originally posted by Larrym
    Really like this post and ones like it. Thx, DEEBS11! (◠﹏◠)
    Photos of what's hidden until one actually takes things apart. Sure, there's a genuine sense of discovery/surprise when you remove something for the first time to look at what's underneath and go, "WUT!??" (⊙_◎)
    In this situation, much better to know-before-you-go. (ʘ‿ʘ)
    Also this illustrates exactly why I was so confused by my inter-web searches-
    "The O-ring is made from Nitrile Rubber and is OIL Resistant"
    STILL feeling like a crash test dummy fOaR choosing EPDM. ¿ⓧ_ⓧﮌ
    I ordered your EPDM one, so there will be two dummys lol. Lots of articles online of EPDM O rings being used in auto brake applications though... including race cars... soooo
    Leave a comment:
  • Ccitis
    replied
    Ah, those photos make sense. I am just waiting on my O rings. If I can keep the stock one,I will be very happy! This site seems to have all the answers for my old XS. Amazing resource.
    Leave a comment:
