New to Japanese, need help with vin info.
    replied
    Leave the name and the post here. We know it now, and will check in on you as you post, so any help will be quicker. Don't try and get it done in a hurry, life happens and motorcycle repair has its own time frame.
    Leave a comment:
  • jgonz
    replied
    I apologize for not posting in a few days. Unfortunately, my day job involves me traveling out of state. I'm usually out at least a couple of weeks. I didn't order parts because nobody will be home to receive them. I did finish up removing the wiring harness which is big because not only can I see everything that I'm working with but, I'm getting a great understanding of where everything goes. I took a crapload of notes, took and am still taking pictures, and I'm constantly revising my plans for this bike. In addition, my mechanic volunteered his shop for me to work on the engine when the time comes. All in all, it's been a pretty cool experience. It's going to be a couple of weeks until I get back so probably no updates, or maybe I'll think of something I can post. I'm thinking of moving this thread and possibly renaming it because I don't' think the title holds true anymore. Any thoughts?
    Anybody care to share any suggestions while I'm out that I can chew on? I'll be looking online a lot for parts and probably watching youtube videos. I'm already itching to get back and get to work again.
    Thanks for any help guys!
    Leave a comment:
    replied
    Like this. Mine is a 78 with the black connectors. Yours might be 1980+ style.
ID:	877778 Click image for larger version
ID:	877779 Click image for larger version
ID:	877780 Click image for larger version
    Leave a comment:
    replied
    This is the part. XS650 after market items. You will notice the connectors are not the same. You must solder your connectors to the harness.
    https://www.ebay.com/itm/174165779424
    Click image for larger version  Name:	ezgif-5-a0391fdf36.jpg Views:	0 Size:	87.4 KB ID:	877774 Click image for larger version  Name:	ezgif-5-2a84a5de22.jpg Views:	0 Size:	170.9 KB ID:	877775 Click image for larger version  Name:	ezgif-5-7fc9629f20.jpg Views:	0 Size:	225.7 KB ID:	877776
    Leave a comment:
    replied
    Ignition switch new (Chinese-could-be-crap-but-might-work-for-a few-years).
    Considering the size of the wires coming out of that my guess is it won't handle all the juice that's going to headed through that switch, using the switch to trigger a relay is probably a good idea.
    Leave a comment:
  • jgonz
    replied
ID:	877767 Click image for larger version
ID:	877768 Click image for larger version
    ​ ​​​​​​​I haven't updated in a couple of days since I've been otherwise occupied (other projects plus work)
    I noticed the connectors for the hand controls are in pretty good shape. I'd like to save the hand controls so I drilled the screws out since they were corroded in place. It was very dirty in there with spiderwebs along with dirt and sand. the run/stop switch is frozen in place and the start button is gone. I also broke the brake switch wiring connector but not on the wire side so maybe I can salvage that.
    I'd like to wire this up as close to the way it's supposed to be as possible. Usually with choppers I do away with turn signals, speedo, lights, etc. All my bikes have only the headlamp, taillight, and horn. Since I want to make this a cafe racer styled bike, I want to keep the electronics with perhaps an update. At the very least, I want to wire it correctly and make changes from there.
    If anyone knows of a set of aftermarket controls that will work, that would be ok also.... in any case, I will be keeping much of the wiring and connectors. I'm also going to clean up the frame and am looking at painting it. It looks like it's bone dry after sitting for so long and I will have to service it so I will more likely than not have to pull all the mechanicals out. Brake system will be rebuild/replaced where applicable.
    Deebs11 - Thank you for your input and I will have some questions for you in a while.
    I'll keep posts coming.
    ​​​​​​​thanks all
    Leave a comment:
    replied
    https://www.ebay.com/itm/15463008759...Bk9SR5rJys2oYw
    Leave a comment:
    replied
    Ignition switch used.
    https://www.ebay.com/itm/38662513491...Bk9SR7Lfq82oYw
    Leave a comment:
    replied
    Or you can repair your existing harness with new connectors.
    Click image for larger version  Name:	Opera Snapshot_2024-01-26_031512_www.vintageconnections.com.png Views:	0 Size:	495.0 KB ID:	877672
    Leave a comment:
    replied
    Here is a used one.
    https://www.ebay.com/itm/31501430441...Bk9SR4zo1MyoYw
    Leave a comment:
  • jgonz
    replied
    Deebs, thanks for the input! This is exactly what I needed and was looking for. I didn't get to work on the bike today because I was spending the day with my son. I'll be doing more work in the coming days, though. What do people do about connectors? My friend I got the bike from told me today that there are actually wiring harnesses available, but I have not verified that.
    That's a sharp shovel, btw. I love shovels, my first ride was a shovel and I do believe that there is nothing like the sound of a shovelhead. Happy riding!!!
    Leave a comment:
    replied
    Nothing like a nice ole tractor.
ID:	877612 Click image for larger version
    Leave a comment:
    replied
    Rear master cylinder rebuild kit. These can be tough to work on but there is lots of info on this forum.
    https://www.ebay.com/itm/363306829991
    Leave a comment:
    replied
    Master cylinders. I usually chuck the front and use this one. I run these on several of my bikes and they have held up in all kinds of weather for over 8 years. It's important to note that you need the large 16mm piston for dual disc brakes. These also have a brake light switch. Your brake light wires are inside the headlight housing and hook up easy to this.
    https://www.ebay.com/itm/202821810271
    Leave a comment:
    replied
    Parts lists. You will need these to determine the factory part number in some instances. Then you can search for the part on eBay. It usually comes up.
    https://www.partzilla.com/catalog/ya...e/1981/xs1100h
Name:	Opera Snapshot_2024-01-25_045628_www.yamahapartshouse.com.png
    Leave a comment:
