Running rich
  • BLOWCLVL
    replied
    Originally posted by skids
    Wow! If it is repeatable with the choke, you are definately onto something, but I'll be damned if I can figure out the interaction. It would seem to eliminate electrical issues from ignition. I just wonder of the levels in the bowls are still too low and with that boost of gas from the choke, the engine pulls enough air velocity to lift the main needles. I know I am not explaining this very well...
    LOL confusing I know.
    Leave a comment:
    replied
    Originally posted by BLOWCLVL
    I had it wide open when I flicked the choke on and off.
    I have tried running in prime no change. Have not tried running with the vacuum line off the controller.
    Leave a comment:
  • donebysunday
    replied
    Resistance
    is futile !
    You have the resister plugs there and your running resister plug caps so you are doubling the resistance
    Just wondering as I have NGK BPR7ES in there right now?
    Leave a comment:
  • BLOWCLVL
    replied
    I think at 4000 and above, you are not using the pilot circuit much, including the mixture screws and pilot jets. I wonder if when you were fiddling with the choke, you were momentarily off the throttle allowing the bowls to catch-up with gas. Have you tried running without the vacuum operated fuel controller? If not, try running on prime.
    Leave a comment:
    replied
    Now the weird thing. I decided to put the 105 mains in and the 45 pilots. My slide needles are set to the middle and my mixture screws are 1 and 1/4 turns out. Took the bike for a ride and runs with same issues. once I get to 4000 rpm it backfires like mad and doesn't go anymore. I reach down pull the choke to see if it helps and it does not. Put the choke back in and 2 seconds later I whack the throttle and the bitch climbs all the way up to 7000 rpm and does not hesitate for the rest of my ride. Turn off the bike have a coffee and its back to its old self again until I repeat the process with the choke. So tell me what causes that.
    Leave a comment:
    replied
    It sounds like the enricher circuit (choke) is dumping excessive fuel into the mix which you compensated for with smaller jets. When the enricher is opened and then closed. it temporarily closes off the additional fuel and allows for a leaner mixture. May want to take them apart and inspect.
    Leave a comment:
  • BLOWCLVL
    replied
    Leave a comment:
  • BLOWCLVL
    replied
    The manual isn't terribly clear, the 15K value for the secondaries is with the plug caps OFF, just measuring bare wire to bare wire. The caps will probably have ~5k ohms ea, and so if they do, then it adds up....5+5+15=~25Kohms.
    Yep you are right. Rechecked without the caps and much closer to the 15k oms.
    Leave a comment:
    replied
    Leave a comment:
  • BLOWCLVL
    replied
    ok so I decide to check my coil resistance and according to http://www.xs11.com/forum/showthread.php?t=583 I should have 1.5 oms on the primary side and I do. The secondary side (spark plug side) says I should have 15k oms. One coil has 25k oms the other is at 25m ohms. Could this be the issue or am I not doing it right.
    Leave a comment:
  • BLOWCLVL
    replied
    Oh another clue maybe to the issue. The left exhaust pipe is much hotter to the touch than the right after I come back from a ride.
    Leave a comment:
  • BLOWCLVL
    replied
    BP6ES is the correct plug, the ones you have are a step colder, shouldn't really make that much difference.
    That's what I figured. Just trying to find other options with the issue
    Leave a comment:
    replied
    Leave a comment:
  • BLOWCLVL
    replied
    Leave a comment:
  • BLOWCLVL
    replied
    What spark plugs are you all running?
    Leave a comment:
