TDC adjustment
    replied
    each shim size = .002 in.
    Leave a comment:
  • coolbikr4684
    replied
    So I messed up the numbers on the previous post. I mixed up mm and inches, good thing I always measure twice and cut once.
    So my shims weren't as tight as I originally thought there was clearance but minimally. Measurements were done in inches.
    E1 .008 Y285
    E2 .008 Y285
    E3 .008 Y285
    E4 .008 Y280
    I1 .005 Y280
    I2 .006 Y275
    I3 .006 Y275
    I4 .005 Y285
    If I follow the chart that I have seen on some of the threads I would need to change to
    E1 280
    E2 280
    E3 280
    E4 265
    I1 275
    I2 260
    I3 260
    I4 280
    Just want to confirm before I go and buy/exchange them.
    __________________
    Leave a comment:
  • coolbikr4684
    replied
    E1 .008 Y285
    E2 .008 Y285
    E3 .008 Y285
    E4 .008 Y280
    I1 .005 Y280
    I2 .006 Y275
    I3 .006 Y275
    I4 .005 Y275
    If I follow the chart that I have on some of the threads I would need to change to
    1 E275
    2 E275
    3 E275
    4 E270
    1 I265
    2 I265
    3 I265
    4 I270
    Just want to confirm before I go and buy/exchange some
    Leave a comment:
    replied
    Originally posted by Bonz
    Back to the fuel filters... If your in tank filter towers are in good condition, the paper filters do nothing. Bikes have been run decades and decades and decades with the filter towers in the tank. If stuff is getting through the tank filters, assuming they are in good condition, you have bigger problems!
    I run some little lawn mower filters anyway. Peace of mind.
    Leave a comment:
    replied
    Leave a comment:
    replied
    Leave a comment:
  • coolbikr4684
    replied
    When measuring for the shims all my valves are tight so ho do I measure for the correct size? I'm guessing I have to remove the shim and than measure with no shim installed and do the math from there. I just want to make sure I'm measuring correctly before I dive into it and start it.
    Leave a comment:
    replied
    Originally posted by coolbikr4684
    I'm pretty sure I measured correctly. Well than I will keep it parked until Sunday
    If they are all that tight you could burn a valve.
    Leave a comment:
  • coolbikr4684
    replied
    Leave a comment:
    replied
    When replacing the shims and valve adjustment, how do I do it if the shims are tight. All the threads I find mention I measure the space between but my thinnest shim won't even go in.
    Are you measuring them correctly? 180ยบ opposite the highest point on the lobe where it contacts the shim?
    Leave a comment:
  • MadHatter4119
    replied
    That's a good question...If I remember correctly...I would say you shouldn't drive it...But I never own a inline 4 engine before...Doesn't the engine run hotter if they are tight...I have always been told a little valve chatter noise is far better than them being tight...Your Call
    Leave a comment:
  • coolbikr4684
    replied
    Can I still drive my xs if the valves are tight? I drive 14 miles to and from work and won't be able to work on the valves into Sunday.
    Leave a comment:
  • MPittma100
    replied
    Valves
    As the valve seats wear, the valves go UP in the cylinder head.
    This closes the lash gap. That is why the lash gets smaller. We are programed to think just the opposite.
    A special tool and a selection of shims is needed to perform the valve adjustments. When performing this repair, always turn the engine by hand. Do NOT use the starter to turn engine while adjusting valves.
    Here is a link to the procedure:
    Some enthusiasts say to remove the cams to adjust valves - a totally incorrect procedure.
    Leave a comment:
    replied
    Take the shim out, look at the number printed on the bottom, put one in with a number that is less, take your measurement and determine the correct number needed.
    Leave a comment:
  • coolbikr4684
    replied
    The valves will get tight as they wear, not loose. You should go through and get the valve adjustment correct BEFORE trying anything else. I like to set valves at the high, or open end of the spec. They make a little noise, but they also will not tighten and burn any time soon.
    AFTER adjusting the valves, then do a chop test with the plugs. If they are white, you are probably running out of gas. Black would be too much gas.
    Leave a comment:
