Power loss
  • CaptonZap
    replied
    Another test for coil output is to take two old plugs and break the ground wires off. Plug the plugs into the two ignition wires, lay the plugs on the head, and crank the starter. The distance from the center electrode to the shell should need a minimum of 6 to 8 Kilo Volts to spark across the gap, (in ambient air, and yes, a difference in altitude will affect the break down voltage, but work with me here.) The spark should be a blue color, and have a sharp snap. If it is yellow or orange, the spark is weak. Try new coils.
    The breakdown field for air is 30kV/cm. Plus or minus.
    CZ
    Leave a comment:
    replied
    Yes Brant, that's exactly what I'm saying. I pulled the tank and seat and disconnected each connector and checked voltage at each one.
    I am, however, going to run a wire straight from the battery to the ballast resistor just to be sure. As soon as I get a chance.
    I just want to be sure I'm not the idiot you think I am.
    Leave a comment:
    replied
    Originally posted by BA80
    Checked it in San Antonio. As I said before, with all other fuses pulled but the main and ignition it was only 2/10 difference. About the same as from one side of the fuse to the other.
    Still haven't said you had checked the coil input voltage. Pull the dern tank off, and unplug coils, meter probes into feed wires for the voltage check TO the coils. Also with those wires of, check across coil post in ohms position on meter, More than .2 drop or rise, kiss those coils goodbye. Sounds like yo said you still have stock coils..........file 13 them anyways.
    Leave a comment:
    replied
    Originally posted by motoman
    Double check voltage input at coils.............better be the same as batt, with keyon.
    Leave a comment:
    replied
    Just changed that before the trip to Michigan when my charging system cooked.
    Charging system is working better now than it ever has. 13.75v at
    about 3500.
    Leave a comment:
    replied
    It seems like whenever the engine is under the greatest loads. Even under part throttle going slowly in lower gears it bogs but the lower gears it can push through and take off, it the upper gears it can't get to a high enough RPM to push through it because it's working too hard.
    I can get to 90 pretty easy if I don't use full throttle but as soon as I do it just flattens out.
    BTW, whenyou pull that carb bank off and fuel bowls removed, remove the pilot jets and inspct ckosely,,,,,,,,,like with a magnifying glass and goo LED light........be surprised what ytou'll see trapped in there. Can't be blown out from teeny atomizing end, but a small wire brush wire will fish out foreign matter,.........DAHIK. Also, pointed round toothpic for reeming the sidehole wall surfaces DOES work.
    Leave a comment:
    replied
    about 3500.
    Leave a comment:
    replied
    Not even sure what it does, but only thing I can think of you haven't tried is the Reg/Rect. ?
    Leave a comment:
    replied
    Hmmmmm............orange spark.......
    Leave a comment:
    replied
    I'd forget about the Dyna coils and THEIR price. Locally, I'd opt for a set of Honda vfr coils...........way cheaper($30-$40)..........besides they work WAY awesomely!. Just have your meter WITh you to check ohms across the two input poles on each coil. Not all the vfr coils ae 3ohm coils. They ARE plug'n'play as far as mounting, plus you get to make up your own plug wire sets........worked for me awesomely on the Vwnturer.......and still do. Extremely rare that Honda coils throw craps on you also. Just my advice Greg, since I'm using them on my Venturer, Even extremely rich running, they don't miss a lick firing, and have no idea bike is way..way rich unless I get a whif of the exhaust while riding hiway speeds down the road or pulling plugs for a look see. In other words, eliminate the coils your now using on the bike!
    Yeah, I thought about that Brant but I work 10 hours a day 5 days a week and I never get an opportunity to run all the way to the north side of town and pilfer the salvage pile. Maybe I can get Vlad to get me some.
    Leave a comment:
    replied
    Originally posted by tomcos67
    You have to try coils.?
    I've tried 2 different sets. One set of 3ohm coils from an 81 without the ballast resistor and the set of 1.5ohm w/ballast resistor coils I've got on there now. They are the originals.
    Same, same.
    I have one more set here on JW's SG I could try I suppose. I have another set but they are in KC on Russ' bench in his garage. Been trying to contact him but he's ignoring me I guess.
    I just don't understand some people. Use their house like a hotel, drink all their beer, and mess up their garage and then they ignore you.
    Leave a comment:
    replied
    I've considered buying a set of Dyna Coils if that turns out to be the issue. I can get a new set w/wires on fleabay for about $140.
    Leave a comment:
    replied
    Leave a comment:
  • tomcos67
    replied
    sounds like
    Leave a comment:
  • red bandit
    replied
    Is it strictly throttle related? Is it -as soon as WOT it bogs/noses over and then gets thru it and runs or WOT runs to a certain rpm than bogs, gets thru it and rums?
    Leave a comment:
