Power loss
    replied
    Originally posted by rdmcguy
    Having followed this thread for a while,but may have missed how spark plugs were reading(color wise )to this point .
    You mentioned trying different carb banks, but did not mention if ALL of them were jetted the same as eachother?..I have had tired engines (low compression )run progressively worse as they get more tired
    Wouldn't run for s**t at low rpms but ok at mid /high rpms .
    Don't know if this will be of any help but ....
    ......maybe carbon buildup in exhaust port ?...
    Good luck and don't give up ,
    Read through post #1 carefully.
    Leave a comment:
    replied
    You're getting spark, but the indications seem to be that it's a somewhat weak spark. The pickup coils just tell the TCI when it's time to send electricity to the ignition coils, which they seem to be doing. If you had a problem with the pickups you'd expect it to show up by plugs 1 & 4 looking different than 2 & 3. But I don't think changing the pickups is going to get you a hotter spark. I also don't think the pickups performance would improve at higher rpms, and judging from the video it sounds like it runs better at high rpms. But if you've got another set it couldn't hurt to change 'em. Who knows, maybe you'll get lucky. And it's better to be lucky than good any day.
    Have you checked the gap on your plugs? Should be .028-.032, and with old coils closer to .028 would probably be in order.
    He ain't usin the old coils..........may wanna read back thru the threads.
    Leave a comment:
  • rdmcguy
    replied
    From out of the blue
    Leave a comment:
  • blue giant
    replied
    Greg,
    I have been following this thread hoping the answer would reveal itself. The voice in my head says the issue is fuel related. I'm thinking fuel starvation. Have you had the petcocks apart lately? Have you had the petcocks out of the tank to check the condition of the tower screens?
    Just my two cents. I ordered petcock kits for the 80 special I'm currently reviving, one because they wont stop seeping and two because I seem to have a fuel starvation/flow issue from the right side valve, even on prime.
    Paul
    Leave a comment:
  • dbeardslee
    replied
    I mentioned this before, but didn't see an answer. Have you checked the plug gaps? They tend to grow over time, so depending on how old they are, it might not be a bad idea to make sure they're still in the .028-.032 range. Might try cleaning and setting them at .028. JAT
    Leave a comment:
    replied
    A lot.
    Just test rode the new pick ups.........@&%$*$#*&%$%
    No difference.
    Leave a comment:
  • dbeardslee
    replied
    Originally posted by BA80
    When I pulled the old ones off I tested them on the bench. One coil seems to have ohms fluctuating when I move the wires around.
    How much was it fluctuating?
    Leave a comment:
    replied
    I tested them on the bike and they tested good. I was thinking like you, it's just a signal to the TCI. BUT, what if that signal is scrambled at a cetain frequency?
    Cross your fingers.
    Leave a comment:
  • dbeardslee
    replied
    Put some different resistor caps on, no difference.
    Next step change the ONLY part I haven't yet. The pick up coils.
    Leave a comment:
    replied
    Leave a comment:
    replied
    These new ones don't come apart Ron, I already tried. They are all integral, molded together.
    Upon closer inspection the short 90 degree caps don't come apart but the longer 120 degree caps do.
    Leave a comment:
  • Brent
    replied
    It seems like whenever the engine is under the greatest loads. Even under part throttle going slowly in lower gears it bogs but the lower gears it can push through and take off, it the upper gears it can't get to a high enough RPM to push through it because it's working too hard.
    I can get to 90 pretty easy if I don't use full throttle but as soon as I do it just flattens out.
    Hi Greg,
    I have had & seen some bikes run sort of like you describe. Turned out to be insufficient fuel supply. Fuel lines kinked or fuel lining collapsed where it hides inside, Partially clogged filter or screens inside tank, Bad pressure regulator with low pressure to fuel injectors. YMMV l . I believe my screens may be dirty since mine runs better if tank is over 1/2 full. fuel level in your tank make any difference?
    Not at all sure, but at least fuel lines are not too high$$$$
    Good luck wrenching.
    Brent
    Leave a comment:
    replied
    I know - I've been following the thread. When somebody quotes me from atop their high-horse I generally respond, and I'm sure you recall the way the conversation was going several days ago.
    hate that when that happens.
    Leave a comment:
  • dbeardslee
    replied
    I got a set of CB700 coils for free Doug. Still the same. In fact, the video is with them installed.
    Leave a comment:
    replied
    Leave a comment:
