Power loss
  • dbeardslee
    replied
    Originally posted by BA80
    It's a thought Doug but actually I'm pretty mean to this engine most of the time. Ha ha ha ha......I've never been accused of carboning up an engine before.
    Point taken. LoL
    Leave a comment:
    replied
    Leave a comment:
  • dbeardslee
    replied
    Here's a crazy idea for you. Somebody mentioned a carboned up head as a potential cause, which got me thinking. You might try warming it up, removing the pods, and misting water from a spray bottle across the carb bells while it's running. It'll knock a lot of carbon off the top of the cylinders and the valves and might help it breath a little better... if that's the problem. You'll know if it's working by black smoke coming out of the tail pipes.
    Leave a comment:
    replied
    Not too many places to check Ron. All the intake boots are brand new and all the vacuum caps are good. The thing sycs and idles good.
    This is the most perplexing thing I've ever run into. Motorcycle or automotive.
    Besides, a vacuum leak would lean it out and that seems to be what it's liking. It ran ALMOST normal on the way home from work.
    Leave a comment:
  • ViperRon
    replied
    Greg I am with you that the issue with mixture just does not happen like that. I agree you have went threw everything electrical and it must be fuel some how but with what you have done seems you are now treating the symptom with adjustments you never had to make before I know you have went threw carbs probably 10 times as much as me and you would have seen a problem. I hate to say it but I'd be thinking about dumping that gas all of it in something else and get some somewhere else before I custom tuned them carbs. what I saw in the video you made does not appear to be a jet nozzle or needle problem as they do not get better with throttle and there is no power threw it and it improves. I know you have checked but Is there any place you could have a vacuum leak and missed it.
    Leave a comment:
  • dbeardslee
    replied
    Just out of curiosity, when is the last time you cleaned your pods? Do you run them oiled or dry?
    Leave a comment:
    replied
    That was my first thought also but no one else's bike is having issues and I ode it to and from San Antonio (565 mi one way) and it did it all the way down and back. Gas every hundred miles. It would all have to be the same.
    Leave a comment:
    replied
    Living in California, I would say take a look at what your public servants have done for you, IE fuel now being sold! Sounds to me as if something changed in the fuel, and that may be causing your problems. Oil companies can change formulas as long as the State goes along with it. The exact formula is a "secret", so you'll never get a full answer. My guess is they pulled some of the "oxygenator" out of it, so you need a little less fuel volume to keep the same weight of fuel to air.
    Leave a comment:
    replied
    Yeah, thinking sideways.
    3 different sets of carbs, 3 different sets of needle jets. I would have noticed any irregularities when cleaning them.
    Leave a comment:
  • dbeardslee
    replied
    All jets are new except the stock sizes.
    Needle jets. A.K.A. emulsion tubes.
    Leave a comment:
    replied
    Leave a comment:
  • dbeardslee
    replied
    Yes. What has me spinning is, as I said in the #1 post, I've tried 3 DIFFERENT sets of carbs on there with 3 different sizes of main jets and 2 of pilots.
    And the fact that the original set of carbs I started with had been on there untouched for 4 or 5 years and all of a sudden this pops up. Why would my engine gradually change fuel requirements?
    Original set ; 45 pilots and 140 mains, needle center notch (on bike running great for 4 - 5 years)
    1st changed set; 45 pilots 142.5 mains, needle center notch (ran good for about a month)
    2nd set 45 pilots 137.5 mains, needle center notch
    current set 42.5 pilots 140 mains, needle started on center moved 1 lean
    I'm now running 1 size smaller pilot, same main, and the needle set 1 lean. A leaner setup than ran great for several years. Why would it change?
    I've heard some say that needles wear, and also that they can wear the inside of the needle jet, particularly if they're cocked sideways in the slide a bit. 'Course that doesn't explain why you'd get the same condition in three different sets of carbs, unless they were all worn. Which seems unlikely. When you've got them out you might check and see if there's any noticeable wear, and you might check the bores on the needle jets and see if they're round or oblong. Might double check the needles themselves too, and see if they've got any markings on them.
    Leave a comment:
    replied
    When you say you dropped the needles do you mean you went up one notch with the clip?
    Leave a comment:
  • dbeardslee
    replied
    Here's the latest; I took the pods off and ran without any filters for a test. IT WAS BETTER!
    It liked leaner better. So, I pulled the carbs and dropped the needles one notch. Ran it again WITH the pods and the low gear stumble is quite a bit less and the high gear low RPM bog is almost gone.
    I think tomorrow I'll drop them down to the last notch and see how it is.
    I'm having trouble understanding how the engines fuel requirements have gradually changed over the last 4 - 5 months.
    It's amazing how much difference the clip position on those needles makes. When you say you dropped the needles do you mean you went up one notch with the clip?
    Leave a comment:
    replied
    Leave a comment:
