Power loss
    replied
    I would try advancing the timing until it pings, then back it off a little. Definitely that will give the bike more pep. You might lose that midrange bog, who knows.
    Leave a comment:
    replied
    Hey Greg,
    I've stayed out of this for the most part because I'm not a REAL mechanic.
    I just finished doing a quick NET search regarding LOW COMPRESSION on 4 stroke engines, symptoms and such.
    Poor throttle response
    Lack of power/acceleration
    Increase fuel consumption.
    And you said eariler that it's run fine for 40-50K miles....is that the total mileage of the engine, or is that just the miles you've put on it since you've gotten it or put it into service??
    Here's a quote from www.dansmc.com site:
    SO.... it looks like to me that your compression levels are really a bit on the low side and from all you've done/tried, that it sounds like the engine is just wearing out! Post have been made in this thread fairly quickly, and so other REAL mechanics may have not seen your compression stats??
    ANY INPUT from other mechs with regards to these comp levels probably contributing to the aforementioned symptoms since it seems like nothing else that he's tried has made any difference?
    What's that phrase Sherlock liked to quote,
    Good try T.C...........have to be REALLY low to have any effect on vacuum diaphrams OR venturi velocity though.
    Leave a comment:
    replied
    Originally posted by BA80
    I did a compression check a little bit ago and it's 115/105/105/115. No issue there.
    Hey Greg,
    100 PSI is the minimum. It should be 125 to 150, and some engines have as high as 170 PSI or more. Yes, an engine can run with lower compression, but it will run very poorly. I've seen old, big, multi-cylinder outboards run with as little as 65 PSI and some lawnmowers run even less. However, for motorcycle engines 100 PSI is really on deaths doorway. Use your time to rebuild the engine, not to get another five or ten hours of life (maybe!) out of it.
    Once you eliminate the impossible, whatever remains, no matter how improbable, must be the truth.
    Leave a comment:
  • dbeardslee
    replied
    Ha ha ha..........this ain't my first rodeo.
    Never doubted it. I figure at this stage, after all the stuff that you've checked, it doesn't hurt to spit out words to see where they'll splatter. Maybe something will click.
    It does seem that you may be onto something with the needle position, but I agree with you - everything that happens has a cause. Just doing some spitballing to try and figure out what the cause was on this one.
    Leave a comment:
    replied
    I remember you changing the cams and setting the timing but didn't see any mention of checking the chain. But if the cams are dead on the dots when #1 is at TDC that does sort of suggest that the chain is okay.
    Leave a comment:
  • dbeardslee
    replied
    If you BOTH will read back to the beginning of this thread you'll see that I went to check valve clearances an found some damage to the cam lobes (pics included) and I actually changed out the cams.
    BTW, cam timing was, and is, dead on.
    Leave a comment:
    replied
    Leave a comment:
  • dbeardslee
    replied
    Originally posted by stereomind
    hrm, no telling. valves beating themselves into place, cam chain stretching, carbon buildup, false air.. or maybe it's just the right age for menopause.
    I was about to post almost exactly the same thing when my e-mail went bing bong. LoL One thing that hasn't been checked yet to my recollection is the condition of the cam chain. Easy enough to do. If you've got a stock tensioner take it out, cock it, put it back in and let it go and then lock it down. Remove it and measure how far out the pad is, then release the nut and see how much farther it comes out. Might give you an idea of how long your cam chain has grown.
    Leave a comment:
  • stereomind
    replied
    Leave a comment:
    replied
    Again, I will HAVE TO ask. Why would the fuel demands change after 40 - 50 K miles? There HAS to be an explanation.
    This engine isn't a computer. It doesn't get automatic updates.
    Leave a comment:
  • stereomind
    replied
    Right, but you're about out of stuff to replace, other than the mill itself.
    So far, nothing has worked, other than leaning the mixture. This is consistent with "getting worse when hot" symptom. Going back to old mixture settings and then trying to "fix" the original problem seems counter-productive.
    You mentioned your compression numbers wasn't it around 105 ish?.. was that dry/cold?
    Leave a comment:
    replied
    "fixed itself" doesn't exist. What, should I ride across country and hope it doesn't "unfix itself"?
    Leave a comment:
  • stereomind
    replied
    I would file it under "something was wrong before and was affecting fuel mileage but somehow fixed itself now" and treat the symptom... lol
    Leave a comment:
    replied
    a plug chop would have revealed this as a fuel mixture issue....... but that's none of my business..
    Pretty tough to do the chop chop when the damn thing won't go.
    Still wouldn't explain WHY fuel demands would change for no apparent reason. That has me baffled.
    Leave a comment:
  • stereomind
    replied
    Leave a comment:
