Power loss
  • dbeardslee
    replied
    Just comparing the plug to the spark plug condition matrix in the manual, it most closely resembles a carbon fouled plug. Here's what the service manual says:
    - Identified by black, dry fluffy carbon deposits on insulator tips, exposed shell surfaces and electrodes.
    - Caused by too cold a plug, weak ignition, dirty air cleaner, too rich a fuel mixture, or excessive idling. Can be cleaned.
    But the funny thing is, the electrodes themselves look pretty good - looks lean in the center and rich on the outside. I'd clean them off good with a wire brush making sure to get between the insulator and threaded part. If you get enough guck down in there sometimes it will short a plug out. Blow 'em off good so's you don't get any loose carbon in the cylinder and see if it makes a difference. JAT
    Leave a comment:
  • MPittma100
    replied
    Plug
    I am looking at the center and side electrode basing the color/read off of that. Agreed, there is some black around the threads. Rich to me is ALL black. It looks like it is trying to run right from what I see. What mileage are you getting with the current carb setting?
    If that is rich with the lean (OEM) carb settings, not much left other than fuel?
    Leave a comment:
    replied
    That's rich Mike. It's nearly all black.
    Leave a comment:
  • MPittma100
    replied
    Good Plug Color
    Originally posted by BA80
    I don't know Mike but nothing I've tried, and I've tried a LOT of different things, has made a significant difference.
    The leaner I go the better it gets. I'm as lean as I can go without buying more jets.
    I pulled one just to check. This is with Mac 4 into 2 and pods with 42.5 pilots, 137.5 mains, needle on center groove. All stock jetting.
    Nothing wrong with that plug color. Should get your best MPG with that. Would not go any leaner that stock jets/needle setting.
    Leave a comment:
  • MPittma100
    replied
    Lean
    Agreed, that is definitely lean. But, not a bad thing. Suggested the octane booster to prove/disprove the quality of the gas you have available.
    Leave a comment:
    replied
    Leave a comment:
  • dbeardslee
    replied
    If you cannot find any better gas, try some NOS octane booster (local parts store) and test ride with that in the gas to see if you have an improvement/fix. Otherwise, search for E0 if you have not already done so.
    I have a supercharged vehicle with same compression as the 11s. It responds favorably to the addition of this product. It is not cheap, but it may help solve your issue.
    Another alternative is to find a station with unleaded racing gas. Normally is 100 octane.
    The question that comes to mind is what did they do to the gas? Did they add more corn (E15, E85)?
    Octane is a measure of the compressibility of gas, not it's "explosiveness." You generally want to run the lowest octane you can without getting pre-ignition. For my F model that's 87 octane. High octane gas tends to gum stuff up and it will foul plugs faster than lower octane gas. At least that's been my experience with it. My $.02
    Leave a comment:
  • MPittma100
    replied
    Gas
    Back to a completely stock jetting setup and it still isn't right. I'm starting to think they've changed the fuel at the pump. Ken is having issues with his too.
    Leave a comment:
    replied
    Leave a comment:
  • dbeardslee
    replied
    Let me know what the shipping is....
    I'll pay to ship 'em - it's only going to be a few bucks. I tend to send stuff via USPS's Slow Boat service.
    Leave a comment:
    replied
    Leave a comment:
  • dbeardslee
    replied
    Yes, I did. Thanks but if I decide to put some on I'll get some Dynas. I understand those Mikes coils tend to lay down on ya.
    That's true. My first set of black ones lasted 7k miles. But these are pretty new and they're free if you want to try them for diagnostic purposes. I wouldn't trust them for the long haul either, which is why they're not on Betsy anymore.
    Leave a comment:
    replied
    Leave a comment:
    replied
    It helped but it wouldn't catch and go by itself. The bowl orifices are clear.
    Leave a comment:
  • dbeardslee
    replied
    So, those 2 leaner settings on the needle are basically useless. Too bad because it seemed to run better off idle there.
    I wouldn't say that. A little bigger jets in conjunction with the lower needles might give you enough gas for a cold start, as well as changing the rpm at which the main fully opens. But again, I'd be suspicious of the bowl orifices if the enricher had no effect.
    Did you read post #181?
    Leave a comment:
