I've already picked up genuine mikuni: (4)42.5 (4)45 (4)47.5 pilots and (4)110 mains from the dealer. The jets that we're in there are not marked and must go. I never thought to check the bell jets. Hopin' they're stock.
Just a little side rant... the local Yamaha dealer doesn't stock jets of any type and had no idea what jets I needed for a stock application. I had to search their parts books for what I needed after they told me "it's hard to match jets". I looked at the guy like he had 3 heads and said "luckily, everything has a part number". I only went to these guys so I wouldn't have to wait for eBay shipping and it still took 4 days for their parts to arrive. Amateurs.
81 SH project
Welcome...........ALL jets need to be Genuine Mikuni's, having their logo.............no aftermarket(K&L or RD). To see the correct size on sides of pilot jets may require some MAGNIFICATION
Leave a comment:
Thank you motoman, I'll check the bell screws and make sure they're 185. You'll hear about it if they're not, I'm sure. Thanks againLeave a comment:
Re-jet to stock and you'll be good....110mains/42.5pilotsThank you Gordon! Eastcoaster is the man. He let me strip a bunch of parts from his 81 special. I nabbed just about everything I could carry and I'm now the proud owner of a proper xs1100 air box. I love the bike with the box on. Now I'm planning on digging into my carbs again and rejetting to stock spec before the final sync.
At sea level, does the stock setup already run lean? I have the green dyna coils and I will be using a k&n drop in filter so I'd imagine I'll need to finagle the jets a lil for some more gas. Should I reject to stock and go from there or will my mods be too much for stock jets. Would I be wrong if I went up one on the primary for the baseline? Sorry if this question is like beating a dead horse.
. Make sure air-jet(small Mikuni) on back of bells are all 185's.
Leave a comment:
At sea level, does the stock setup already run lean? I have the green dyna coils and I will be using a k&n drop in filter so I'd imagine I'll need to finagle the jets a lil for some more gas. Should I reject to stock and go from there or will my mods be too much for stock jets. Would I be wrong if I went up one on the primary for the baseline? Sorry if this question is like beating a dead horse.Leave a comment:
Leave a comment:
Radio Shack will have a diode, if you can get to a store before they are bankrupt and closed.
A couple of amp rating should be good, because I think they power the headlight relay, if my memory is not affected by the eggnog. They won't look like the broken one, but will be a round black cylinder with a white band on one end. I hope you remember which end the white half was on, as they will only work one way. The up side is that if you put it in backwards, and it doesn't work, you can turn it around and no harm done.
CZLeave a comment:
Duh! I managed to source a suitable diode from the original hacked-up harness. It was safely tucked away under about 4 inches of electrical rubber-tape. l wish I would have thought of that before searching for a replacement. Looking at the diode, I probably broke it when I swapped harnesses.Leave a comment:
Well, I found this thing in the wiring diagram, it's listed simply as #55 "Diode". It's smack dab in the center of the supplementary sh wiring diagram. How do I go about replacing this guy?
sorry about the quality of the photo. It is half green an half white and 100% broke.
I hope I didn't use too much grease! I may not have even done it right. After cleaning the connections, I smeared grease on only the mate side of the female connectors and slid everything together. I didn't think at all about the grease being an insulator but that is a very good point. I have since cleaned any connections that lead to relays of grease.
Like I said, I am still having some electrical issues. Digging deeper into the harness, I found this link that is either melted at center or fatigued in half. I imagine I can replace this link with an inline fuse. Is this what I want to do? If so what size fuse? What am I looking at here?
Leave a comment:
An interesting read Marty! What little bit of dielectic grease I have in strategic locations, I promise I'll keep the Bentley 'grounded'........you have a MerryChristmas and be safe if rolling on 2wheels!
Leave a comment:
dielectric grease is an insulator
As written by Wayne Orwig, MGNOC Georgia State Rep.
Quote:
Using Dielectric Grease on connectors.
A lot of people use dielectric grease on connectors. Some people mistakenly believe that dieletric grease is a conductor. In fact, it is just the opposite; it is an insulator. Dielectric grease is typically made of silicone grease.
As an insulator, dielectric grease is good for use on spark plug boots. This was one of the original applications on vehicles when the high-energy ignition systems came out. It can help insulate the connector and, in particular on a motorcycle where it can get wet, it waterproofs the spark plug boot. And, because it is silicone, it is fairly stable at high temperatures and won't affect the rubber and plastics.
So why would you put an insulator on a connector? The idea is that you use a thin layer. When you push the connector together the grease is pushed out of the way enough to get a connection and the surrounding grease then keeps out water and oxygen. The connector will be protected from the environment and less likely to corrode. Plus, the silicone is safe for the plastics and PVC insulation.
That sounds good, so far; so why not smear it on everything? Well there are a number of good reasons.
First, silicone grease outgases constantly. If the silicone gas gets near a connector or a contact, such as a relay, and there is a spark, the spark at the contact can create silicon dioxide. Some people even suggest that the silicone gas from dielectric grease can travel many feet through the unsulation on a wire and damage a contact on the other end. Omron states that even their sealed switches can be damaged by nearby silicone grease outgassing. Reference the following links for more info:
http://www.omron.com/ecb/products/pdf/en-d2vw.pdf
Lubricating electrical switches | Archive content from Machine Design
Second, it is an insulator. It can prevent contacts from touching. If you do use it, use a very thin layer.
Third, if you have a corroded connection, silicone grease will not help. In fact, it may make it worse. It can never improve anything. Dielectric grease will never make a poor connection better.
Fourth, it attracts dust and dirt and it hardens over time. This means that if you smear a lot of silicone grease on connectors you may see nearby relays, switches, or points fail later on. Since silicone grease does nothing at all to improve the connection and, in fact, may insulate the contacts in the connector increasing the resistance the connector may still fail.
So what do you do? Look for a contact enhancer/lube. While most contact cleaners are simple solvents that just wash the connector off there are contact enhancers that deoxidize the contact surface and actually work to lower the contact resistance (make a better connection). Most contact enhancers leave a lubricant behind that protects the metal and continue to deoxidize the metal and improve the connection. They can work to lower the resistance and make a better contact as time goes by. The best you can hope for from dielectric grease is that it seals it enough to not get worse. I have used Caig Deoxit on my bikes for a few years now. I first found out about this on my job when I had to correct an issue in a connector system that could not tolerate even 5 thousandths of an ohm of resistance drift. We had a connector in the field that had been improperly plated and was starting to drift, mostly in warm humid areas like Florida. Our testing showed that the Caig Deoxit could be a good long-term fix. We ended up using the Deoxit to stabilize the bad units until we could get corrected wiring harnesses built with the correct connectors. We also put a layer of Deoxit on the new parts to protect and keep them clean over their lifetime. This solved the drift issue that we had.
I still use a small amount of silicone grease on my spark plug caps. It helps to waterproof them and makes it easier to pull the cap off, but I use it in very small amounts and never near a relay or switch.Leave a comment:
Good call on the dyna coils, they are awesome. I can feel the increase in pressure coming out of my tail pipes from just these coils. Installation was easy enough. The hardest part was sliding the boots around the ignition wire. Mounting the coils so they didn't contact the frame proved to be a bit of a task, but a trip to the hardware store and a little metal work performed with a BFH did the trick.
I removed the entire harness again and let it soak in white vinegar/ salt for a few days and then neutralized it with some baking soda and water. After that I let it dry for a day, flipping it here and there to let the sunlight do its thing. I gave a generous helping of dielectric grease to every connector and plugged everything in. Unfortunately, it was getting dark as I was finishing up and I wasn't able to check my voltage at the coils. I'm hoping for no drop off from the battery this time.
Next thing to do is find why my signals and brake light don't work. Looks like I'll be at it with the multimeter again (oh joy).Leave a comment:
Hey guys, I found the terminals and boots on brillman also, just had to dig a little deeper into their site. I'm planning on getting these. Any advice?
https://www.brillman.com/store/produ...coil-boot-1999
https://www.brillman.com/store/produ...l-terminal-139
https://www.brillman.com/store/confi...-the-foot-1836Leave a comment:
Thanks guys, green coil's in the mail. Motoman, I wasn't planing on using both mains at the same time. I purchased (4) 110 and (4) 115. Mine are the 5gl16 (I know this because 1 was wrong (it was too short), I had to get 1 replacement. I will need some larger pilots probably because I'm using k&n cone filters.
I see brillman offers new-old style copper core, cotton clothed, non suppression, 7mm ignition wires. I love the style. I talked to their rep and he said they should be fine for my application. Does anyone know where I can get just coil boots and coil-side leads for the dyna coils? Should I just get the recommended 7mm wires on the Z1 site? These have the coil-ends and boots.Leave a comment:
Leave a comment:
