Cheapest price fork brace???
Fair comment Cobia, but I live in a country where straight and flat is a novelty. New Zealand is built of mountains and Valleys, where twisties are a daily fact of life for bikers. Where I live you'd be hard pressed to find more than 5 miles of straight road in every hundred. And I don't ride like a nana. I just didn't like what a brace did to the handling, so i took it off.Leave a comment:
I have some thoughts on all our divergent replies. Maybe it all pertains to our riding styles and situations. If you don't encounter twisties and sweepers on your way to work and ride the super slab most of the time you'll probably won't notice the difference.
And don't think that in flat FL I'm carving any canyons, but I do take advantage of opportunities.Leave a comment:
Certainly did install it correctly James. Theyre not rocket science, and ive been working on bikes for many, many years. Perhaps i didnt word it correctly, or i lost you with Kiwi vernacular, but i didnt mean it hindered the travel of the forks. 'Stiffening the front end' is Kiwi for taking the flex out, and after riding for years without one, i found it uncomfortable with one. I found the flex was predictable, and i learned to ride it perfectly well without the brace. When i sold the bike, the brace was in the box of parts, and unless it comes as standard, i'll never bother with one again.Last edited by b.walker5; 12-06-2013, 12:05 AM.Leave a comment:
I can attest to the improvement in the handling of Phil's bike with the FJ front end, it rides as if it's on rails.
Yet, for all of us still riding with stock front ends, my uneducamated theory is this. Whenever you can provide another anchor point and shorten the 3+' of travel between the triple trees and the axle you're going to have a more responsive steering response. There's something to be said for tying the tubes from the trees to the bottom of the tubes in order to keep the sliders and wheels running true and responsive.Leave a comment:
Yep Steve, after riding with this mod for a couple of years, it's so much more solid now.Leave a comment:
If you really want to improve the XS's handling, there's this....
Leave a comment:
I'm not an engineer or anything close. I just figured common sense came into play and that a "fork brace" was self-explanatory, that it acted as a "brace" to "support" the forks. How can that not be helpful to a bike that rides like a bent paperclip at high speeds in the curves?Leave a comment:
I didn't want to go there because the value of it is limited in a forum discussion but I also cant sit back and let someone provide completely inaccurate information either. Would you sit back and say nothing if someone said running less than 32 psi in your front tire will result in you crashing and burning?Leave a comment:
I think Hoek's law doesn't really get to the root if the issue and neither is the moment (or second moment) of inertia. The brace basically helps the two lowers act as a rigid unit. It does shorten the effective length of the forks and this probably helps to prevent the very slight twisting action between the triple trees and the axle. Given the fact that two of my standards had little affect from the brace and only one other did improve, all else being equal, I would say that the brace compensated for some slop in the fork action of that bike.Leave a comment:
This is taken from an old article about making the XS handle better, it explains the need for a fork brace pretty well...
"The XS11's front fork lacks torsional stiffness--something it shares with most bikes that do not clamp the front axle on both sides. The most important factor in front fork stiffness is how well the front axle is clamped. Of course, the XS11's axle is clamped only on one side. When new, friction between the fork leg and the axle will hold it pretty well. After a few thousand miles, however, the axle polishes the hole it fits into and the fork assembly will begin to move around. This is one of the reasons wobble problems tend to show up after several thousand miles. The answer is a fork brace."Leave a comment:
After installing the TKat fork brace this summer, i cannot see why they didn't include one from the factory. I do ride mine hard, so there is a need, but i would not have a bike without one now. They work well!Leave a comment:
Have a TKAT on my SG. Front end has never felt wiggley. XJ air shocks on back handle that end real well. I don't ride too close to the machine's limits, and this set up has always seemed adequate to my needs.Leave a comment:
Fork brace, without question firms up front fork flexing. Stationary testing of that with and without brace proves it works(test it if you don't believe it). Engineering theories is all good, but real-world application IS the bottom line. Majority of the time, alot of difference between the two. The XS11's handling stock, as we know is limited and scarey at best on occassion. The fork brace resolves that......to the point that the rear dual shock set-up fails to follow suit. Short of mono-shocking that end of bike, it is what it is. In a nutshell, if you want superb power, handling and braking in the same package, go buy a friggin' new scoot
Leave a comment:
Leave a comment:
