engine knock low end
    replied
    Besides the random "knock" I get from the advance unit, the harmonic "tinging" that is being generated by the timing rotor, seemingly just from spinning, is annoying as heck too.
    So, say I swap over the vacuum can from the SG and the "knock" goes away... Where do I find another vacuum can?
    Leave a comment:
    replied
    The vacuum is never steady when it's run off one cylinder as these are but much smoother at higher RPM. With the vacuum advance pod hooked to the carb there is no vacuum at idle though and is somewhat restricted by the orifice in the carb throat.
    Leave a comment:
    replied
    Hey motoman,
    Good ideas, all!
    Is the vacuum signal constant and even, coming off the carb? With a cylinder drawing fuel/air through the carb and the piston rising/falling, wouldn't that naturally lead to pulsing? i.e. pulsing in the lower rpm ranges would be more pervalent and par for the course.
    Wouldn't a pinhole in the diaphragm pulse at all rpm? It is dead smooth in rotation for the final amount of travel to full rotation.
    I need to look at the SG while running and the timing cover off. I never paid attention to pulsing or not on that bike, so it will give me a good comparison of the amount of pulsing and go from there.
    The 80G runs as well as the 80SG in all areas of throttle response, roll-on, WOT, et al. It even averages 2-4 more mpg than the SG on the whole.
    Ok, I'll keep you all posted over the weekend.
    Leave a comment:
    replied
    Originally posted by Bonz
    No damper. Hmmm.... I have an 80SG that is quiet and no damper. Weird that an 80G would be noisy, but noisy it is. That's the first I've heard of a damper on the inside of the timing cover.
    Got me thinking... How could a guy put some strips of old bike inner tube in there, to make a damper of sorts, and keep them from coming loose and winding up in the works?
    You COULD gorilla glue pieces of tube in there.........or you could fix the problem. If that advance dances back and forth, a pinhole in diaphram IS possible. An ignition miss on #2 can cause this too, as well as a really bad carb sync, or in need of. Could also swap out the vacuum can off that red Special and see if advance quits dancing. If it don't, I would suspect an ignition/low idle voltage issue, or carbs idle mix/sync gone array. BTW, as you've figured I'm sure, John had some scoot issues which caused us to just beat it out of Denver 4:30 in afternoon headed south for BuenaVista, rain most of way.
    Leave a comment:
  • ViperRon
    replied
    They make pads to paste on the bottom of stainless steel sinks to dampen noise one of these may help also as they are specifically designed to absorb noise.
    Leave a comment:
    replied
    I can't see how a "form of detonation at cruise" could sound like rod knock...
    It does. Worried the hell out of me when I first got my SG.
    Leave a comment:
    replied
    Me thinks Yamahs had noisy vacuum advance units on some bikes, period.
    Leave a comment:
    replied
    A combination of both I'm sure. I've noticed that the lower the idle the more it pulses. I'm idling at 1100 - 1200 and don't have that issue with either bike.
    That top end knock at 4000 - 4500 is a non issue. Ignore it. It causes no damage at all it's just something you have to deal with. The replacement vacuum advance units are no longer available.
    Leave a comment:
    replied
    Dang Tarzan, you are good! Thanks for the consolation that I'm not going crazy and that the bike has a legitimate noise that is simply annoying at this point in it's life.
    I am going to coat the inside and try to insulate the noise away from my ears.
    Leave a comment:
    replied
    The pickup wires were fixed/modified by a previous owner, so the pulsing could have led to that issue.
    I wonder.... If the pulsing is really what does the pick up wires in, vs. normal rotation?
    Leave a comment:
  • tarzan
    replied
    I found it in another thread.
    Leave a comment:
    replied
    10-4 on that Tarzan... It runs great and is annoying as heck.
    Leave a comment:
    replied
    Is the pulsing of the pick up coil not normal, or is that par for the course?
    Pulsing is usually caused by hooking the vacuum hose to the manifold instead of the No 2 carb nipple. If there is a lot of motion in the pickup assembly causing noise, and it bothers you, and you have it hooked to the carb nipple, what else can you do? This constant vibration might also cause your pickup coil wires to get brittle and break. Just thinking out loud...
    Leave a comment:
  • tarzan
    replied
    There was a TSB on that very issue for the 80 model year. It has something to do with the timing. I used to have it saved on my computer.One of my SG's had that problem. It seems like the solution the dealers were given was to replace the advance mechanism.I will try to find the Bulletin. I don't believe it will actually hurt anything running it that way. It's just annoying.
    Leave a comment:
    replied
    I am not sure that the pulses are an issue. The bike runs strong and smooth as my 80SG which is literally in near perfect mechanical shape and condition.
    Keep in mind, I was running it on the centerstand in neutral manipulating the throttle, so there was no load on it at all. Not sure if that is anything of note, but thought I'd mention it.
    Leave a comment:
