Ease up Doug.
I'm pretty sue I have a decent head if you want. PM me.
ACCT Installed Wrong?
I guess you have learned to not go your own way on this before you check out stuff like owners manual and the forum and all that kind of stuff. I was mostly just ribbing you about slow down and all that until you went at it like a starved man at a Smorgasbord!
I know Scott was more than willing to help you after this happened but life goes on and an offer like he made was nothing to be sneezed at. Too bad he is now busy and you will have to pay a price for what was once offered free.
Most here who have bent valves do not report that they had to replace guides or seats. From the posts I have seen it is a simple matter of replacing a known weak/bent valve with a good one. A bit of lapping and everybody is happy.
You can do it! Just do it! Be patient, ask questions before...not after...and check out a few answers before doing something. Often members have disagreeing opinions on procedures or other things.
You rushed in here like a hurricane and let us think that our beautiful bikes were number one in your eyes. Now you have a wee bit of trouble and you do not think it is worth it.
Give your head a shake and decide what you want and then let us know. We can most certainly help! The decision is yours, to have an XS11 or a cheap clone.Leave a comment:
For less than $280 you can pick up a spare motor from someone and just replace the whole thing.
JohnLeave a comment:
Hey Ian, as far as I know, you cannot cut new seats in those heads, unless you get some custom ground valves, etc. You should be just fine lapping your valves yourself and mounting head on....just make sure you go through the process, without skipping any steps
just my $.02Leave a comment:
With labor rates in the $85 an hour range, it ads up quickly. There might be other XSives in your area that could guide and help you do the work. The ole "give a man a fish he eats today, teach him to fish he eats for a lifetime" thing.Leave a comment:
Update!
Hello Fellas-
Just an update on the bike. Scott has been extremely busy, so he ended-up sending me two gasket kits and the valves from his spare head. I have a buddy that is willing to do the work for me, but it's sounding like more money than it's worth. So far, just for labor it's $280 to clean my head and cut new seats for the valves (as long as no valve guides need replacing). 1 1/2 week turnaround time on that. That's just for the head work. He has not given me a price on putting the head back on the bike, etc. I had no idea it would be this involved and costly.Leave a comment:
"I would check those timing marks one more time."
Hmmm...interesting thought. Make sure it is correct before I proceed? Sounds fishy, but I'll give it a try.Leave a comment:
I look forward to some warm weather to begin tinkering with the bike again! April is the month we might be able to get our bikes on the road for a ride or two until the real warm weather comes!Leave a comment:
DG, that was part of the checking process. I gave her a couple of rotations to make sure, this time, that all was as it should be before I turned the key. Then I went back into the house for a bit and then checked again. My wife asked how the bike was coming and I launched into my deep, profound monologue about how I had screwed up when I got into a hurry and I was going slow and easy this time. She said, "How long has it been since it ran...two years?"
"Uh...yeah, about. Why?"
"Well, you've got the slowest hurry I ever heard of!"Leave a comment:
"not to be a worry wart type, though I am, I would check those timing marks one more time."
Cool, I appreciate it. If I'm not home, my son will let you in the garage. The 5mm hex key is in that big bucket with the rest of the tools I actually use.Leave a comment:
LoHo, not to be a worry wart type, though I am, I would check those timing marks one more time. When I reassemble, I always make sure I pull the chain tight between the crank and the intake cam when I set it in, and then between the cams when I set the exhaust. In other words get all the slack at the front of the engine. I doubt there was enough slack for you to be off a tooth on a cam, but I would rather check it first.Leave a comment:
Another thought:
In my most recent re-assembly, I set the timing marks at T, installed the ACCT, then turned the engine over by hand to insert the other cam sprocket bolts. As I turned the engine I suddenly heard the zzzzip noise and almost soiled myself until I realized that I had created slack and the ACCT was doing its job. As one turns the crank, one takes the slack out of the chain from the front sprocket to the rear sprocket down to the crank, and the ACCT keeps the tension between the crank and the exhaust sprocket where the chain is under the least tension.Leave a comment:
+1 Rasputin,there are no dumb question's,only ugly outcome's for not asking.If you don't understand the answer,keep asking ,I do.lolLeave a comment:
One of the main reasons to keep this thread alive is so others will benefit from the info. It shows everything from the I don't want to wait for an answer to what happened and then still others have experiences that relate to it.
The thing I would like to stress the most is if you do not know....DO NOT simply peruse a post and think you know it. Do some actual reading of that post and then do not take it for gospel but check the manuals and see if they agree with each other.
Once it has been all thought through and you think you know how to do it...Then do not be afraid to ask on this forum for confirmation. There are a boatload of guys who have done it before, or screwed it up or just plain know because of their experience.
I say this because I see more lurkers than members on the site at any one time so they need to know!Leave a comment:
Leave a comment:
