ACCT Installed Wrong?
Hey, I was just going off common sense that I bent the valves. Not sure how going on a ride, parking it and running a test bent them, but I assumed worst-case when I found 0 psi across all cylinders with two different gauges. The bike was not able to be started, and I heard a metallic clanking sound in the #1 cylinder when cranking it. Head is off the bike now, laying in my basement. If I have time tomorrow, I'll pull the valves and take a look at them. My concern was a hole in the piston, which there is not. So, all I can hope for is that this head work won't cost me too much. Not sure what the cost is to get the valves cut.Last edited by IanDMacDonald; 05-16-2013, 09:21 PM. -
OK, I just read the entire post... whoa.
From Post #56:
Maybe I missed something but how can you jump to the conclusion of bent valves when the bike was running fine in your description?Hey Guys. I'll get to checking the valve clearances after class today. But, to clear up the confusion, I'll briefly give a re-cap of what happened over the weekend.
After getting the cams re-aligned, I rotated the crank a bunch of times to make sure they stay aligned. The next morning I synced the carbs (did not re-check the valves), then took it for a ride. My best guess was a mildly bent valve on the number one cylinder as it felt a tad off on power and sound, however all four cylinder pipes were equally hot. I took it for a ten minute ride. No abnormal noise, etc. I got it home and back into the garage for a simple compression test. I disconnected the coil leads so I did not have to mess with grounding the disconnected spark plug, and hooked ny compression tester to cylinder number one. Hit start and got 90 psi, 120 psi a half second later, then 0 with a tapping noise. Hooked it up to cylinder's 2, 3, 4, and got 0 as well. I thought to myself it was a bad gauge, so dug out my back-up gauge. 0 psi across all four cylinders. I hooked up the coils again and tried starting the bike and got nothing.
That's the re-cap.
One thing I never read was how you verified all your valves were actually bent. Were you just making that assumption based on the whanky compression numbers you got?
Whom or how were the bent valves verified?
Where are you in the process of things, did you remove the head yet or taken anything apart?
Have you tried to start and run the bike after the compression test in the above post?
You said you checked compression and had cylinder 1 up to 120 for second but then 0,0,0,0 across the board. If you had a bent valve then I dont believe you would have gotten the 120 psi. All compression testers I've ever used have a check valve in them to record max pressure, so why did yours go back to zero? Something doesnt add up here...
The bigger question is why do you suspect bent valves after it was running and you made no physical changes internally between your ride and compression check?
Lesson #1, never make more than one change at a time. I'd tend to believe that your carb sync is responsible for the power decline and possibly the noise you heard prior to testing compression.
Here's my advice (if you havent torn into the head yet) spin the engine over by hand and if there is no interference, try to start the bike. Possibly ask Scott to check compression again brfore trying to start it but as long as you can rotate it without and interference I would try starting it.Last edited by WMarshy; 05-16-2013, 08:13 PM. Reason: Sory for the double post I ran out of time to edit and didnt like the way I had written the other one...Leave a comment:
All I know is what Scott told me, lol
the following are mods to the bike, Scott's words:
The distributor centrifigul advance curve reduced, allowing the initial to be increased, no vacuum advance.
Head was milled like .060 which left the piston to valve clearance a bit tight at .07 and .08. I can't remember the exact compression, but it may be in the notes. I think it's about 10.8:1. The valves are backcut and the bowls are ported mildly. One puck is shimmed, (I don't like that- I was poor at the time), but it ran for ten years the strong use without a tick.
O2 sensor in the header for jetting. It's rich enough to run open headers.
~40 MPG
Without mufflers it will flip backward without popping the clutch at any speed in 1st gear and most of 2nd. Didn't like the Jardines as much as the pipes that are on there. They reduced the rpm at max horsepower. Makes strong power to 5500-9200 without a hitch.
Scott
__________________
79 F; CNC cut 2nd gear dogs; Ported/Milled head; Modded Airbox 8x8 bottom auto filter; more initial timing adv. , less Cent., no Vac. Adv.Last edited by IanDMacDonald; 05-16-2013, 06:35 PM.Leave a comment:
So is he recommending a certain angle cut to compliment the port job he did? Or did he nick a seat?
Sorry I didnt read the entire post... what's his experience level with porting heads?
The only reason I could see cutting the seats is if they were damaged/repaired or if you wanted a different angle for performance reasons. Otherwise IMO I dont believe the benefit is worth the cost. Especially when you could just lap them and skip all the trouble of cutting the seat.
Besides, say you cut new seats, are you going to grind the valve too? I dont suspect he knows what the valve seat angles are right now so logically the proper thing to do it cut the seat and grind the valve to match the seat... is he recommending grinding the valve too?
Im not saying Scott is wrong but just letting you know that if it was my bike this is what I would be asking/challenging him on, and maybe learn something in the process.Last edited by WMarshy; 05-16-2013, 06:30 PM.Leave a comment:
I know he ported and polished the head. Whatever he did to it required a certain degree cut on the valves.Leave a comment:
I just dont understand why Scott is telling you the valve seats need cutting. What "work" was done on the head that warrants cutting the seats in his opinion?Leave a comment:
Yeah, I read that in another thread. I just re-read Steve's thread regarding proper cam installation. I hope I can find a cheap way to get those valves cut and get this bike going.Leave a comment:
Just another little fact you may not know about with these engines. If the cams are installed and the head is on the bench. Be careful about rotating the cams. If one of the intakes is open and you open the exhaust on the same cylinder they will hit each other. Also, dont set the head flat on the bench with any valve open, it could get bent.Found a few hours and pulled the head this afternoon. Didn't really have time to look it over, nothing stuck out like a piston with a hole. My buddy is a master mechanic, and he will help me pull the valves. He said the project may not require anything more than a simple lap job. However, I know Scott said that the valves needed a cut due to the head being worked on.Leave a comment:
... and probably more reliable in the long run. Get another head, just lap the valves (something you can do at home for cheap) if you feel the need and want the assurance of good valve seal.
$280 should pay for the head and any/all tools needed to 'touch' it up...Leave a comment:
Is the suggestion out there that it would be cheaper and easier to just drop another head on the bike?Leave a comment:
Maybe that idea was out of ignorance, but, don't you have to cut the chain to pull the head off, or was that on the 750 only? Unless I pull the cams off . . .Leave a comment:
Hey Fellas-
No offense taken Doug. You are absolutely right! The guy that I was asking about all of this is definitely a pro when it comes to bikes. The valves Scott sent me definitely need some cleaning up. I know that he had a certain cut he put on the valves. So, I'll ask him what exactly he did with those before I dig in. I have not even taken the head off yet, because I want to make sure that I do not screw the pooch on everything again. I know I have to cut the chain and buy a master link for that. The thing that screwed this all up was the timing of the cams. So, I'll need some help with that. Also, I'll look into a valve spring tool for the valves.Leave a comment:
Sorry. I did not think I was being harsh. I know Scott has been in contact with me and he did his best to accommodate Ian. Now that life has moved on, I am only hoping that Ian will take in what the forum has to offer. Spare head and engines do come up but most are too expensive due to shipping. I was simply trying to give him a little push to get him too see that is was worth the effort.
If I came across as harsh I do apologize.Leave a comment:
Leave a comment:
