Have a little question.
    replied
    The resistor are spliced into the power wire. No grounding, it just goes in-line.
    Leave a comment:
  • Yard Dogg
    replied
    Originally posted by skids
    If flashing is an issue you may want to go with an electronic flasher unit. I lost my automatic cancelling function, but it is no big deal to me. I just manually cancel the turn signals.
    How many watts are your bulbs? What flasher did you use? I'd like the canceller but I'm starting to think it's a hassle.
    Leave a comment:
    replied
    Leave a comment:
  • Yard Dogg
    replied
    Alright now I'm really thrown off. My light bulbs themselves are resistors. The trouble is, they are not letting enough current past to make the flasher work. When I hook up the resistor, am I supposed to hook it the power source feeding the bulbs and then ground it? Because then the resistor would act like another light bulb to fool the flasher into thinking it's getting the full 54W. Am I getting close?
    Leave a comment:
  • Yard Dogg
    replied
    How about this one. 5 Ohm 34 Watt rated. 5 Ohm to draw a little more (faster blink), and 34 Watt cause 34 Watts + 20 Watts (2 bulbs) = 54 Watts.
    http://www.mouser.com/ProductDetail/...tbwEUegv9A0%3d
    Leave a comment:
  • Yard Dogg
    replied
    That should be close. I figure if I get one a little higher on Ohms then they will blink a little faster. Right, now I know what to do.
    Leave a comment:
    replied
    Depending on what numbers you plug in, you can get different results. One thing to remember that while these are a '12 volt' system, they actually operate closer to 14 volts. It should be noted that most automotive lamp watt ratings are figured at the higher voltage. So a 4 ohm resistor will be very close. The higher the resistance, the less current it will draw...
    Leave a comment:
  • Yard Dogg
    replied
    And if this is correct, than I'm going to have trouble finding such a precise resistor I'm sure. So I should probably order a resistor that is just a little more draw rather than a little less right? So if I find a resistor that is 4.75 Ohms, that would be better than one that is 4.25 Ohms right?
    Leave a comment:
  • Yard Dogg
    started a topic Have a little question.
    Crazy Steve gave my the idea of using inline resistors to make my turn signals flash again after switching to smaller bulbs so I can keep my auto cancelling unit. I found the Ohms Law conversion calculator online and need a little clarification. I already messaged him, but I already know that I am missing something.
    My bulbs are 10W each, single filament. The required draw on the flasher needs to be 54W. So in the calculator I entered 20W for 2 bulbs (left, right), then 12V cause this is a 12V system. I have every reason to believe I'm getting my full 12V, my wiring has been completely gone through. The calculator came up with 7.2 Ohms.
    I then entered 54W for the stock bulbs, 12V, and came up with 2.666- Ohms.
    My question is, do I now subtract 2.666-from 7.2 to figure out what size resistor I need to draw enough current for operating the flasher? If that's correct, than I would need a 4.534 resistor?
