Have a little question.
    replied
    Originally posted by Yard Dogg
    I took the cover off the OEM flasher and am seeing some kind of resistor or maybe a capacitor even, IDK. There must be a simple way to modify it to blink with less load..
    Look here: http://www.xs11.com/forum/showthread...ht=turn&page=3 (post 33) for an explanation of how the OEM 'flasher' works. It would be possible to modify one to operate with a different load, but figuring out the values of the needed capacitor/resistor is the trick. You're now dealing with reactance, not simple resistance, and the equipment needed to determine what you have and would need is well beyond the scope of most home hobbyists. You would have to 'tune' each flasher for the individual load.
    This is the far easier mod: http://www.xs11.com/forum/showthread...highlight=turn This mod (with the 'right' flasher) can flash any load while retaining the auto-cancel feature.
    Leave a comment:
  • Yard Dogg
    replied
    Only reason I went with these lights is cause 2 of mine were broken when I bought the bike. I should have installed factories but I thought I'd be cool and install smaller ones for the looks alone. My fault I'm having to deal with this. But like was stated before, an electronic 2 prong flasher solved it except for auto cancelling. I never wait for that thing to work anyway, I always end up shutting them off myself.
    Leave a comment:
  • CaptonZap
    replied
    Sounds good to me CZ (former EE student of Kettering). Yes, you are correct in the ratings of the resistors used. Problem is, when you have to start looking for placed that sell the high wattage resistors, by the time you found them, ordered them, etc., you could have bought your $9 electronic flasher from Auto Zone and been done with the whole ordeal.
    Yep, I'm still not sure about what the benefit of LED's is, other than bulb life.
    And I have yet to replace an incandescent OEM bulb, after years of riding an XS. So the cost difference can't be that big an issue.
    But hey, what ever lights your bulb, so to speak.
    CZ
    Leave a comment:
    replied
    Thanks. I took the cover off the OEM flasher and am seeing some kind of resistor or maybe a capacitor even, IDK. There must be a simple way to modify it to blink with less load.
    It is a green tubular type and says 150 (Ohm symbol) J, also 1W, and a 10 and looks like a lower case a.
    Btw, the above is a ceramic resistor. If it was a cap, it would be rated in farads.
    Leave a comment:
    replied
    Leave a comment:
  • CaptonZap
    replied
    With speakers....wiring 8 ohm speakers in series means 16 ohms, in parallel means 4 ohm load and a good way to blow an amp if too many are wired and resistance drops too low.
    The electromagnetic impulses have multiple pathways which reduce resistance, like opening another checkout stand at WalMart reduces waiting.
    Why is it not the same with the light resistor - wiring it in series to add resistance?
    John
    John, don't let these guys confuse you with all this talk about ohms resistance. What they are after is watts per unit time.
    Watts is volts times amps. And is a unit of power. You buy watts from the power company, not volts or amps. An analogy is that watts is gallons of water, and amps is how many gallons are going by the faucet per second.
    But you can measure watts by using volts and amps. Watts = volts X amps
    To alter the watts, you can change either the volts or the amps.
    If the volts remain the same, 12 V, and you want to change the amps, you have to deal with Ohm's law, which state that the Volts = the amps x the resistance in the circuit. So, if the volts remain the same, the only way to change the amps is to change the resistance. As the resistance goes up, the amps go down, so that the product always equals the volts.
    So these guys are playing with the resistance as a means of getting the watt flow of a high resistance (low watt) bulb, and, by adding a resister, get the total flow to equal the watt flow of the stock bulb.
    ( In this case, I am using watts and amps in the same way, which is not technically correct. Watts are a measure of the total number of electrons that get transferred. Amps are the number that go past a given point in a given amount of time. In this case, since they are the cause of the effect that we are concerned with, I use either term to describe the arrangement of the components that we can use to alter the outcome).
    Resisters in series, (one after the other), add their resistance values, and the total resistance goes up. And the amps, and thus the watts, goes down.
    Resisters in parallel, (side by side), see the total resistance go down, and the amps, and thus the watts, go up.
    Well, maybe I confused you with an attempt at an explanation.
    One thing that I haven't seen mentioned in this discussion, is that resisters have a watt rating, and if it is exceeded, the resister gets hot, and can burn out. (And "up", anything that is in contact with it.) And the cost of high wattage resisters is rather high, and they need a way to dissipate the heat that they generate. (A light bulb is a high wattage resister, and you know what sort of heat they put out.) So the 1 watt resisters that you buy at Radio Shack are not going to be able to carry the load that needs to be carried, even though the resistance is right to satisfy the calculations.
    I'll quit, before I make it more confusing.
    CZ
    Leave a comment:
  • jwhughes3
    replied
    John
    Leave a comment:
    replied
    Sorry Nate, but one end has to be grounded. You're trying to add load, putting the resistor in series with the light will reduce the load.
    You are correct Steve. My bad.
    Leave a comment:
  • Yard Dogg
    replied
    Leave a comment:
    replied
    Originally posted by natemoen
    The resistor are spliced into the power wire. No grounding, it just goes in-line.
    Dogg, you'll need two resistors, one for each side and they have to be installed after the handlebar switch. Easiest way would be to connect one end of the resistor to either the front or rear light power wire, then ground the other end. They will get hot, so mount them with that in mind....
    Leave a comment:
  • Yard Dogg
    replied
    Dammit Dawg,
    nobody's gonna see a pathetic little 10W signal!
    Put the big ones back on fer chrissake, nobody want's to see you in the obits.
    LMFAO! They light up okay. I'll be alright.
    I already took the advice of the last post. It occurred to me that I had an electronic flasher in my truck and a spare to replace it, so I plugged it in and they blink.
    I tried to hook the Y/G wire to the electronic flasher to make them work, no blinky. Was hoping to crack the mysterious mythical cancelling unit, no such luck yet, not anything quick and painless anyway. I'm done with it for now. I was wanting to get the canceller to work so I could varify that the speed sensor in the Virago pods would work with the cancelling unit for sure. I think it does. Another day for that.
    Leave a comment:
    replied
    Keep in-mind, most resistors have a tolerance band of +/- 5%, so, if you go with a 5 ohm resistor, you are still within tolerance. If you wanted to be anal, you could use multiple resistors in-series to each other to add up to the desired resistance value. If you really wanted to make it easy on yourself, buy an electronic flasher from Auto Zone and be done with it. Half the time I'm cancelling the signals on my own anyways, so, what's the big deal losing self-cancelling signals?
    Leave a comment:
    replied
    - - - My bulbs are 10W each, single filament. - - -
    Dammit Dawg,
    Leave a comment:
  • Yard Dogg
    replied
    I'm beginning to think, that the only reason they had to use a relay to operate the flasher unit, is because the old school bulbs were drawing so much power it would be easier on the cancelling unit. But with LED's or little bulbs like mine the power consumption shouldn't be a problem. Know what I mean Vern?
    Leave a comment:
  • Yard Dogg
    replied
    I'm going to do a little testing tomorrow. Cause it seems like I tested the auto cancelling unit on my last ride and even though my blinkers wouldn't blink, they still cancelled if I remember right. There must be a way around that damned flasher relay. I need to learn exactly what the Y/G and Y/R wires do coming and going to the cancelling unit.
    So far what I've found, the Y/G is live with the ignition on, and blinkers on or off. You would think it would be one or the other. So I'm thinking that once the blinkers are activated, a signal is sent through the Y/R wire from the switch, to the cancelling unit, then a signal through the Y/G wire to the flasher relay turning off the signals.
    I've saw the method for using a relay and electronic flasher, I'm just wondering what happens with the Y/G wire when the cancelling unit operates the relay in the OEM flasher. Does it stop powering the relay in the Flasher? If so, than it seems I could just use the Y/G wire to power an electronic flasher, then when the cancelling unit does it's duty, the flasher will loose power and stop flashing. I only say this, cause the cancelling unit has it's own separate power source. So if I can power the flasher through the cancelling unit, viola! Just brainstorming, need to test my theories. I'm going to hook a small light to my handlebars to see what that Y/G wire does while I'm riding. That will tell the tale.
    Leave a comment:
