80G Fork question
  • Rasputin
    replied
    Your new to you cap is in the mail.
    Leave a comment:
  • GLoweVA
    replied
    Originally posted by Rasputin
    OOOps meant if it was the correct one as I only have one left.
    Yes Ras, I'd love to get that from you. I checked right to left and it'll fit. I'll send you a PM tonight.
    Here's some pics I snapped today.
    The G valve itself is 14mm:
    The G cap is 12mm:
    The SG valve cover/cap has a slot for a screwdriver:
    The SG valve is 10mm:
    And the 2 valves are completely different: (like Steve says, they won't interchange)
    Leave a comment:
  • Rasputin
    replied
    Leave a comment:
  • Rasputin
    replied
    Like I said if they are the right ones I will send them to you. If not then they stay here for the time being. If I am correct send me a PM and they will be 10 to 14 days to get to you.
    Leave a comment:
  • GLoweVA
    replied
    Oops! Maybe they are 12mm. I'll measure again in the morning.
    Leave a comment:
  • GLoweVA
    replied
    Originally posted by motoman
    That last pic. is what comes on the 81 Venturer in chrome.
    Yep. The G & H were the only ones to get the 14mm nut and the chrome cover.
    Though it looks like there may be some black ones for some later models.
    Leave a comment:
  • Rasputin
    replied
    George, I believe that you have either measured wrong or my parts bike is wrong. The ones on my G are 12mm. I am not 100% sure they are original either.
    I think that the forks have not been disturbed for some time. That does not mean that the fork caps have not been changed.
    Here are some pics of what I have:
    Yours for a simple PM of your address if they are right for you. If they do not appear right then they may live a long and happy life in my garage.
    Leave a comment:
    replied
    Leave a comment:
  • GLoweVA
    replied
    Found a pic.
    You can see how the whole cap covers the entire air valve.
    Where as the SG caps are different:
    This one is for a XZ550RK VISION 1983, but is the same shape.
    Leave a comment:
  • GLoweVA
    replied
    Update
    So, I ended up getting a GS1100 valve for cheap on fleabay.
    It threaded in just fine into the G forks, but like the previous pics, it's a 10mm nut size like the SG.
    So on the right side, I've got the bigger looking 14mm size and on the right the 10mm one.
    The right side one has the original valve cover/cap which covers the entire thing. (sorry no pic) while the available caps for the smaller SG ones are just like a metal tire air valve cap. (with a slot for a screwdriver on the top)
    I don't have a cap right now, so I just used a plastic valve cap to keep the debris out.
    Now it's time to get the fork seal changed out so I can put some pressure in these forks and hopefully ease up my ride a little.
    Leave a comment:
  • GLoweVA
    replied
    Originally posted by WSL91
    Is there a chance that someone mixed up the caps? Lost the original? Maybe just a cap? Maybe a hens tooth?
    I won't know for sure until I get them apart and verify the springs in there.
    Phil, thanks for looking.
    DCracer25, Thanks for the offer, but my forks are okay, just a leaky seal. I've had the new seals sitting on my shelf for about 6 months, just waiting for an opportunity and enough bravado to get it done.
    Leave a comment:
  • WSL91
    replied
    Leave a comment:
  • DCracer25
    replied
    forks
    I have the complete air assist forks setup for a 81 standard or venture as they call it, needs new seals also would throw in the calipers and brakes even a front fender if you want them for 75.00 plus shipping.
    Leave a comment:
    replied
    Sorry bro, I only have the smaller type for the Special forks which won't help you.
    Leave a comment:
    replied
    George, I may have an extra air valve laying around for the Standard forks. I sent one to another member not too long ago and probably have another, I'll check for you.
    Leave a comment:
