I did the valve clearance by removing the cams, got it back together and she was finally starting to run really good (still working on final sync on the carbs after rebuild / clean). The mileage is a little over 25k and even though I read about on this forum many times I didn’t do the ACCT mod while I was doing the valves (wish I had). I figured with only 25k the manual CCT would hold up for a little while. I took it out for the 5th test ride (only 3 miles) and she was purring when I started hearing a lot of noise from the top end and she started running rough. I babied it home and resolved to do the mod immediately – I thought the CCT got loose and the chain was slapping. I did the ACCT mod and started it and the top end is still making a lot more noise than usual (and she is idling rough). I know with the valve clearances loosened up there will be more noise – but this is a lot. OH S&^%! I kissed a piston, bent a valve, busted a cam cap and generally blew any chances of riding for at least a month while I redo the top end.
So now damage analysis – I checked the compression (while warm, with plugs out, WOT) and got 160, 165, 165, 165. Sweet! So the next thing I check is the cam timing. I took the faring and valve cover off today and the cams look close, but not balls on. When I did the valves I think I remember the cam marks were only slightly off and I redid it and they came out balls on. To me the exhaust cam looks slightly retarded and the intake cam very, very slightly advanced. My question is 2 parts. One tooth on the cam sprocket looks like it would make too large an adjustment on the exhaust much less the intake. If this timing looks ok to you guys what do I look for now? Thanks in advance for the expertise I know you are about to share! Now the Pictures (I know you love them).
1st the Crank Position Indicator.
Next the Intake Cam Timing Mark
Last the Exhaust Cam Timing Mark
She was almost together
I REALLY wish I had done the ACCT when I did the valves!
