Rear wheel bearing LEFT side
    replied
    Have you done 70,000 miles in 4 years?? I'm looking for a 'respekt' emoticon.... Mind you, you're in sunny CA..not like rainy England (it's been raining here for days on end)
    I don't need to tell you this but pack those bearings with a good quality grease! And keep off the jet washer...
    Sunny Caly didn't digest all those miles as he's been 3/4's the way cross the country......and back, more than once, with part of it being a Canadian diversion.................and he's gettin dialed in to do it again. IIRC, last sumer/falls meandering around NorthAmerica alone he tacked on some 7,300mi!.......not countin' that scoot is his primary everyday wheels.
    Leave a comment:
  • James England
    replied
    Originally posted by 3Phase
    I made a 60 mile round trip to Krispy Kreme donuts in beautiful downtown Burbank, Ca. The donuts were fresh out of the tub when I walked in the door and still hot so mine was just slightly krispy, light and fluffy instead of heavy and greasy -- perfect!
    Oh, yes, and Columbo hasn't ridden so smoothly since I put new bearings in... heck, it's over 70,000 miles and four years ago. Time flies and so does my XS11!
    Leave a comment:
    replied
    You're welcome, Scott! Nine days is pretty good considering the distance, eh? I bet your wheel will feel different too, with a new replacement.......
    Leave a comment:
  • James England
    replied
    The two bearings arrived yesterday, the day after Memorial Day, so this time it took nine days to get the parts from the U.K.
    The bearings are carefully packed so both are in excellent shape and one of them is now living the life of Charles Nelson "Needles" Reilly in its new home in the rear wheel hub.
    THANK YOU, JAMES!
    Leave a comment:
    replied
    A fellow XSive just bought two bearings which means that there are now 4 left. If anyone needs one, or thinks they mightneed one, just PM me...
    THANK YOU, JAMES!
    Leave a comment:
  • James England
    replied
    Leave a comment:
  • James England
    replied
    Originally posted by buffalo
    Well It took a couple days longer than the ten day estimate... Got my bearings yesterday which would be 13 days after I sent the payment, still not bad.
    Yeah, average is about 10 days. Usually, any slight delay is due to US Customs stopping an entire plane load of mail for inspection. The record to the USA is 6 days!
    Great you received the bearings. Keep them safe because you'll need one one day
    Leave a comment:
  • buffalo
    replied
    got mine
    Leave a comment:
  • James England
    replied
    I'd go for a replacement FD, definitely. It's the same as if a middle gearbox failed...it would be easier and cheaper to replace it rather than repair it. Even if the required spares are available.
    Oil in the FD can be dirty looking. It has a magnetic drain plug and there may be oily, powdery sludge on it. It doesn't mean the FD is no good though. I think possibly that you don't actually have a problem or need to do anything except drain the oil, clean the drain plug and put new oil in. Failed bearings would be very noticeable and absolutely obvious when the bike is run. If you're not experiencing any noises, vibration or whatever, I don't think you have a problem
    Leave a comment:
    replied
    Just Get Another Drive
    Originally posted by johanr1
    I am busy rebuilding the bike. When I opened it up the oil that came out was not healthy, so I want to replace to be sure. I would like if I could find out with what bearings I could replace the original or can the FD be modified to take a more standard bearing. Getting a whole new final drive will be just to expensive. (ZAR exchange rate!!!)
    <sigh> Was there a lot of metal in the final drive oil, Johan? If there was -- it's toast, don't spend another Rand on it!
    If the oil was just dark or had water in it then put in some fresh oil and change it after a few thousand miles to make sure it stays clean with no metal in it.
    Unless you've got somewhere around $300 USD to drop on new bearings and shims, just get another drive.
    From the boats.net parts list without any shims you'll need to set up the drive with the new bearings:
    Code:
    8	93332-00027-00	BEARING, TAPERED ROLLER	$29.44	$29.44	1	NOT AVAILABLE
    9	1J7-46129-Y0-00	SPACER, EXPANSION	$18.99	$12.31	1
    12	93101-38086-00	OIL SEAL (S-38-50-7)	$12.93	$12.93	1	NOT AVAILABLE
    16	2H7-46122-00-00	RACE, INNER		$25.99	$16.64	1
    17	93317-41510-00	BEARING			$27.09	$27.09	1	NOT AVAILABLE
    18	93101-30084-00	OIL SEAL (S-30-42-7)	$9.53	$7.08	1
    19	1J7-46106-N0-00	BEARING			$91.74	$91.74	1	NOT AVAILABLE
    22	93316-01403-00	BEARING (16014)		$88.99	$58.55	1
    26	93102-70167-00	OIL SEAL (SD-70-90-10) (93102-70166)	$14.79	$10.10	1
    Total: $270.57 US
    At today's exchange rate: 1 USD = 10.5457 ZAR
    R 2,853.38 for bearings.
    Yamaha 1981 XS 1100 H XS1100 Final Drive Assembly
    $42.97 Buy It Now price with free shipping.
    R 453.14 for a used final drive.
    Leave a comment:
  • johanr1
    replied
    Leave a comment:
    replied
    It's not that easy
    Johan,
    If the final drive needle bearings are bad they most likely wiped out the surfaces of the final drive ring gear shaft and possibly the bearing bores in the aluminum final drive housing. Aside from the cost of shipping, you'd probably be better off buying a used final drive that's already set up instead of buying new bearings, then checking/double-checking/triple-checking the clearances and re-shimming as needed.
    You could also think of it as a golden opportunity to try an '850 final drive.
    If you're determined to pound your head against a brick wall and rebuild your final drive: once upon a time I did manage to find the commercial part numbers for all of the bearings. Some of them were very expensive -- buy two or three used drives for the price of one bearing kind of expensive. I didn't keep all of the part numbers so I'd have to tear apart a drive and try to look them up again.
    Leave a comment:
  • James England
    replied
    James,
    These are the 2 needle roller bearings in the drive hub that attaches to the rear wheel.
    I cannot find these from Yamaha, neither do I find any replacement. Please can you help! Are there any substitute bearings that I can use? If so what is the size?
    Ah, you mean the needle roller bearings actually in what people refer to as the final drive, or FD. ie the rear gearbox.
    The bearings I have are only the left wheel bearing, I'm afraid. But, I could ask my international spies in Japan to see if they can get any redundant stock. It does exist; it's just a case of finding it.
    BTW, what makes you think you need to replace them? Have you thought about buying a whole replacement final drive? They aren't particularly expensive, although heavy to ship to SA, I'd say. It might actually be cheaper to replace the FD than to buy the bearings, if I could find any....
    Leave a comment:
  • johanr1
    replied
    James,
    Leave a comment:
  • James England
    replied
    James, Hi,
    I have the XS1100h, and am looking for the 2* needle roller bearings (they are different sizes) in the rear wheel final drive.
    Are these the ones that you have?
    Can I modify this rear hub to take more standard bearings, and if so what will the sizes be?
    Do you mean the wheel bearings? ie the bearings which are in the wheel itself? If so, then you will find that there is only one caged needle roller bearing in the wheel...it goes on the left side of the wheel. The bearing on the right side of the wheel is a standard ball bearing, not a needle bearing, available for only a few dollars just about anywhere.
    No, you'll not be able to modify the wheel to take a different bearing. The left side needs a needle roller bearing and nothing else will do the job satisfactorily or for very long.
    Leave a comment:
