Carb Help!!
Yes, there was also rust under the fuel cap and that didn't help. The UK is renowned for its rain huh? It's June and it's been raining for about 3 weeks. The forecast says rain throughout the entire of June. That's a first!Actually your location is the cause James. With having a 6percent humidity here majority of the time, mine still looks new under there after 30+ years. Here in the States, those residing east, west, or southern coastal areas have issues electrical, etc. that we never see where I live. For example, the electrical wiring and harness on my Venturer looks like it did the day I bought it. Did replace the fuse panel way back when that was first suggested as the holder tangs were britle and one broke and I re-soldered for a temp. fix.Leave a comment:
Actually your location is the cause James. With having a 6percent humidity here majority of the time, mine still looks new under there after 30+ years. Here in the States, those residing east, west, or southern coastal areas have issues electrical, etc. that we never see where I live. For example, the electrical wiring and harness on my Venturer looks like it did the day I bought it. Did replace the fuse panel way back when that was first suggested as the holder tangs were britle and one broke and I re-soldered for a temp. fix.Have you checked that the fuel filler cap vent isn't blocked? It's a common problem. It has a small hole and gauze/foam filter (tiny) and it allows gas to flow out of the tank by allowing air in. In warm/hot weather, it allows for fuel vapour expansion and lets it out. Basically, it allows the tank to 'breathe'
If this vent is partially blocked, you may find that's why the bike will rev to 5,000 but, when under load, dies. The engine could be drinking the fuel faster than it can fill the float bowls (when under load but not when stationary), so you effectively run out of gas, even though might have a tankful!
There is a great thread on the forum about how to remove the vent assembly and clean it. I found mine was making a strange hiss after a run. I posted here about it and got the answer above. When I cleaned it, it was almost totally choked with flaky, crusty stuff...presumably something in the fuel. It sloshes up into the vent when the bike's bouncing along and then evaporates, gradually leaving more and more deposit.Leave a comment:
james is right
I had a similar gas starved situation show up on a XS400 - ran with cap open and problem solved - rebuilt the cap as permanent solution.
Check it first since its so easy to do.
JohnLeave a comment:
Fuel cap vent
There is a great thread on the forum about how to remove the vent assembly and clean it. I found mine was making a strange hiss after a run. I posted here about it and got the answer above. When I cleaned it, it was almost totally choked with flaky, crusty stuff...presumably something in the fuel. It sloshes up into the vent when the bike's bouncing along and then evaporates, gradually leaving more and more deposit.Last edited by James England; 06-26-2012, 11:36 AM.Leave a comment:
I'll be the one to say check your pick up wires... I ahd the same issue a few years ago. Randy fixed them and no more problems.Leave a comment:
Leave a comment:
My brother did the green coils. How would I be able to tell it that resistor is bypassed? And yes is ran fine before putting it away last year besides a spuratic idle. Which is why I replaced the carbs and the bike runs amazing except for this one issue. I'll go out and check for that hole in the bowls of the carb and do I need to check the timing advance while warm?
And yes, I have been syncing the carbs about three times during this process, it hasn't really changed
And what are those brass tubes in the bowls of the carbs? What do they do?Last edited by Haarstad; 06-26-2012, 08:48 AM.Leave a comment:
I had a similar problem, turned out to be a frozen mechanical timing advance.Leave a comment:
I had a similar issue with one of the ones I have been working on. There is a tiny hole in the bottom of the float bowls that goes in to the drilled hole where the brass tube of the carb goes in to. 3 of the 4 of mine were plugged and it took a while with needles, carb cleaner and wire drills to get them cleaned out. Other than that, I'm assuming all the diaphrgms are good?Leave a comment:
Yup, mikes green coils are 3 ohm and the ballast resistor needs to be removed.Leave a comment:
Sounds like it could be a weak spark to me. Mikes green coils are 3.3 ohms, correct? If that is correct then you must bypass your ballast resistor or you will not get a very high secondary voltage buildup in the coils. Have you bypassed the resistor?
BTW, before I changed carbs my setup was jmuch like yours and I settled in on 142.5 main jets and 42.5 pilot jets.Leave a comment:
Carbs
May not be the carbs if jetting does not help matters. Did you check your exhaust system for a possible restriction? Also, what about compression and are you synchronizing the carbs, correct needle jet setting? Just throwing some ideas out there.
DaleLeave a comment:
Did it run well last year before putting it in storage for winter?Leave a comment:
Leave a comment:
