Feed back on Tail light ideas....
Here's how I did my signals, made a light bar out of flat steel and a couple custom L brackets...
I would suggest if your going to mount extra lighting to use as many LEDs as possible. The charging systems on these old bikes won't hold up to a lot of electical appliances and could leave you stranded sometime where you really don't want to be. LEDs use very little juice.
They can seem to be doing fine but on long runs actually be discharging the battery with too many electrical things going on.
JATLeave a comment:
it holds a case of beer and 3 family sized take and bake pizza'sDon, I would use the two red lights on the trunk as brake lights/running lights (if they are dual filament capable) in addition to the stock light. The turn signals I would mount on a bar that attaches to the licence plate holder like the tour pak option would use, JMHO.
Is the trunk there to hold your radio station transmitter?
When the wife and I travel its the only space I get... as she takes both side cases 1 for shoes and 1 for makeup
Leave a comment:
i forgot to mention if I do the amber lights I'll wire the @ old red blinkers into running/stop lights.Leave a comment:
Don, I would use the two red lights on the trunk as brake lights/running lights (if they are dual filament capable) in addition to the stock brake/running light. The turn signals I would mount on a bar that attaches to the licence plate holder like the tour pak option would use, JMHO.
Leave a comment:
Ok guys I've got an idea of something i wanna do. My bike still runs the stock brake light which of course is hiding under the trunk. I've been told by several people that in day light its hard to see under there. So I've got a few ideas.
Idea #1 splice into the blinkers on the trunk to make them dual purpose like a car. So when brake is engaged all 3 light up. When Blinker is turned on that side blinks, when brake is applied the other 2 light up.
Idea #2 Mount these flush mount amber turn signals I've rat holed for some unknown reason from a previous bike project that fell thru
Idea #3 Remove the reflectors of the sides of the brake light and modify the bracket to except my factory R1 signals.
only other idea I have is a red LED strip on the trunk hooked to brake only
Any other ideas welcome guys.
I'd rather not get corn holed in traffic buy a jacked up truck that can't see under the trunk
Tags: None
Leave a comment:
