Final Drive Swap Poll
  • Geezer
    replied
    Without it. I didn't get around to it and I decided I liked the gearing the way it was and decided not to change it after all...
    Geezer
    Leave a comment:
  • James England
    replied
    Originally posted by Geezer
    I bought one off a 850 Midnight Special then I took a couple long rides and decided I didn't want to install it.
    I'm not going to use it and it's up for grabs for the right offer...
    Geezer
    Were the couple of long rides without the swap being done? Or do you mean you did the rides with swap done and then decided to take it off?
    Leave a comment:
  • Geezer
    replied
    Geezer
    Leave a comment:
    replied
    I think it's cause the special guys are too busy chopping their bikes and hardtailing them to be putting the 750 FD on them.
    It is interesting isn't it. I actually would have expected it to be the other way around, but a lot of us standard owners have done the swap, or at least more of us will admit to it than special owners will. Someone send Fred one so we can hear how bad it screws up a sidecar rig.
    I'm wondering actually now well it would work on a rig like Fred's. Would it be a good mod for a situation like his with that big orange wart hanging off the side of it?
    Leave a comment:
    replied
    Good one DG!
    Leave a comment:
    replied
    HBonser,
    I think the shift your seeing is that the Special owners are more cruiser type of guys, so we do not bother with poles as much. As to where the competitive spirit of the typical Standard owner drives them to want to win in the pole, so they vote.
    The above is of course a bunch of bullcrap and I have no clue about the numbers. But sicne it is numbers and a poll, some statistician will use them to prove whatever point it is they want to prove anyway.
    Leave a comment:
    replied
    Let's give it up for XSchop, the founding father of the swap.
    General question for anyone:
    Wasn't the Special the more "popular" model, in terms of numbers of bikes sold, in the States? Maybe I'm wrong, and the Special was sold in smaller numbers, I just remember the magazine articles on this forum indicate the Special outsold the Standard.
    If that's the case, it's interesting that the number of Specials (assuming there were more Specials sold, thus more in the gene pool for the swap) with the swap (based on the poll so far) is lower than the Standards with the swap, being that the Special has shorter gearing by a noticeable amount already vs. the Standard, due to the smaller rear tire.
    Leave a comment:
  • xschop
    replied
    Glad to see you guys are still doing the "6th Gear Mod". Shifting was even smoother when I first did the mod and 4th gear roll-on was much more quicker than 5th gear with the Factory 3.3 FD. My original 750 FD is on a local bike that has 0ver 20K on it plus the few thousand I put on it and has the original copper spacer! It rotates with the shaft and really sees no wear.....
    My $0.03 cents ($0.02 + inflation)
    Leave a comment:
    replied
    I went wild when I did the 750 mod.
    I cut the end off of a bad u-joint yoke and made it the same length as the spacer, then drilled and pinned it to the end of the good yoke so it's splined to the drive shaft and acts like part of the yoke, not just a spacer. No problems with it so far.
    Leave a comment:
  • Clyde K.
    replied
    Aw shucks. Ok, I will wait until morning and do it correctly. Thanks, Clyde
    Leave a comment:
    replied
    Originally posted by Clyde K.
    Phil, I am doing my fd swap as we speak. Would a piece of 1/16 inch aluminum tub work since there isn't any weight bearing involved?
    I used a bronze spacer/bushing from Ace Hardware cut down to 16-17 MM, nice and beefy. I wouldn't risk it and use something too flimsy. If you gotta get her rolling now, go for it.
    Leave a comment:
  • Clyde K.
    replied
    Leave a comment:
    replied
    I looked at things and did't bother with the o-rings. I just put a good coating of RTV underneath the copper pipe, since the shaft I put the pipe on was a spare, I still have the original and I was able to put the pipe on and let the RTV cure before installation so I knew everything was secure first and since it was a metal to metal fit to start, I figured metal to metal now is fine. Everything is still going smoothly, and first Sat in June is a ride through the mountains, so I'll know how it handles it after that ride.
    Leave a comment:
    replied
    I used bronze and coated it with a light film of grease. I think with copper or bronze there is no need to worry about corrosion. If it were me (I know, it ain't) I would just put it together.
    Leave a comment:
  • James England
    replied
    I'm really hoping that I like it though! That's un-scientific but I really have been fed up with the 'high' revs and the engine feeling (IMO) slightly unhappy at 70mph. If the FD swap works out for me, I'll be really pleased. Having said that, if it's not for me, I'll definitely say and explain why.
    I'm looking forward to doing the swap and seeing for myself what it's like.... either way.....
    Leave a comment:
