XS1100 Rescue Mission in Progress
  • essjay
    replied
    Off to Two Wheel Wreckers today to collect new jugs etc to fix her, hurrah. Not long now til she is back riding again, and im on here complaining of 2nd gear problems :P
    Leave a comment:
  • essjay
    replied
    Well thats nice of the PO, just noticed that when he put it all together, he was nice enough to LINE UP ALL THE GAPS IN THE RINGS for me. Makes it nice and pretty to look at. Not the greatest if you want the engine to RUN PROPERLY but aesthetically pleasing at least. In the process of splitting the case, have not taken the engine out of the frame yet, getting at what i can while it is in there. Picking up the new/used set of jugs this Saturday. With luck will be riding in a fortnight or so, hurrah. Although my main riding buddy (other than wife) has had some minor surgery and will not be riding for a month yet, so that is my upper time limit for getting her road ready again, 1st August just to round out the numbers.
    From reading all the info on these bikes, i am still not 100% sure on the exact model, i believe it is just a standard, but it has some of the Special model extras. Think she is just a Bitza. Decided, seeing as she is apart, and looked hideous before, to paint before putting back together also. Have sprayed 80% of the frame with gloss black engine paint, and flipping a coin to see if i paint the engine black and then dress the edges of the fins afterwards, or leave the engine aluminium colour... decisions, somebody make them for me! Leaning towards black engine and polising the face of the fins, think that will still be enough bling for me without hiding the engine completely.
    Leave a comment:
  • essjay
    replied
    OK if my maths is correct, and my measurements, and my info - so all to be checked still - GSXR1100's from 93-98 have a liner 75.5mm factory, we have about 78mm to play with so they should fit in with acceptable wall thickness, standard pistons and rings should fit, looking like it MAY involve the gudgeon pin being machined out to suit a larger pin. Only worries are a slightly different pin height, but the main one being the stroke on a GSXR is shorter, by enough to make the liners non-viable, i do not know. Gah i should be posting this to a new thread when i open that can of worms. I am just the type of guy that sees something that HAS to be possible with the vast array of components out there, and will loose sleep over it until i find all the jigsaw puzzle pieces. Beginning to look more towards the car world, there are some little buzz box parts that should fit quite well. Oh, and the outcome of some junkyard/off the shelf parts and i little bit of machine work on some liners, would be looking about 1228.5 ccs. I think i can knock it together for around $500, though all the sundries and machine work would probably blow that out of the water. Then again, thats still needed for a wiseco big bore kit too.
    Leave a comment:
  • b.walker5
    replied
    Originally posted by essjay
    NZ has some excellent engineers, amazing things coming out of NZ all the time, im sure if you take one out and ask around someone could fab you up a set of them to any specs you like.
    You know, I hadnt thought of that. About a K away from my back door is TurnTru Engineering, the company who built the Ducati powered race bikes for Burt Munro's movie, and the company owner, Noel Atley, is a client of the company I work for. These guys are the specialist precision engineers to the local Aluminium Smelter and if its made of metal and they cant make it, it cant be made. Might have to go and talk to them tomorrow and see if i get scared by thier pricing.
    Leave a comment:
  • essjay
    replied
    Oh, and OEM are available in Australia, to the effect that Yamaha will contact their own preferred machine shop, have them knock out a new one, and it is available to me for $169.95, though im sure after i give a deposit and confirm the order he will point to the fine print and tell me plus gst, plus postage, plus its a raw finish and needs boring.... grumble grumble grumble.
    They can be had, but at a price. NZ has some excellent engineers, amazing things coming out of NZ all the time, im sure if you take one out and ask around someone could fab you up a set of them to any specs you like. Yamaha did a great job on these engines, but we do have some better materials around these days, and it isn't rocket science.
    Leave a comment:
  • essjay
    replied
    Yes no problem, i have a rough list from my references of alternative sleeves, and will still be chatting with a few engineers about fitting them. Ideally we want the correct OD and just a thinner wall (stronger material)
    Some of the early 90's Kawasaki stuff seems to suit, i am not giving up on it. Have found a few so far that will be a drop in replacement for the pistons, with maybe some light machine work to get the lip right on the sleeve. I am keeping the specs for all tolerances etc, and if i get some sleeves and have them machined will get a technical drawing made up and post it here so others can have it copied at local machine shops. So far it looks like we can use some ninja sleeves with all the off the shelf pistons and rings, gudgeon pin sizes match up on some models, and maybe end up in the region of 1300cc. There is plenty of room on the heads to go larger at any rate, not as much at the crankcase end, but if I went that big then it would not be an off the shelf setup, and not really worth doing. It is still an option for me to have some new liners made up from steel, which could go as thin as 1mm on the sleeve, most likely need to use chrome rings with that. There is some debate on steel liners. I will now have some spare jugs to play with here so my eyes and ears are open. Will hash it out with the engineers for viability.
    I know what you are saying, the 1179 kit over here is $900 for parts, gaskets not included. I didn't pay $900 for my whole bike! If i can put something together from off the shelf parts (though most likely it will be from whatever i can find to play with from the junkyard first) then i will certainly let you know, but if it seems feasible i will start a new thread about it.
    Tracking down some copper sheet for head gasket is my next drama, may just go with aluminium instead, easily available. Much prefer copper though.
    Leave a comment:
  • b.walker5
    replied
    Keep us posted on the liner and larger piston thing, wont you. Thats something i would consider doing if they were a common enough piston, with readily available rings. The Wiseco stuff is ridiculously expensive over here and OEM might as well be made of unobtainium. I do have a set of first over pistons on the shelf but no rings. Myself and others did some research a while back and found compatible rings from Hastings mfg in the states, and some cross references to small Ford and Mazda engines but the oil ring is a little wider (.5mm) IIRC and no one seems keen to widen the groove on their pistons in case it's a stuff up.
    Leave a comment:
  • essjay
    replied
    Ok, no we have covered two of the greatest motorcycle legends - Burt Munro and John Britten!
    Helping a lady change a fuse in her car yesterday must have bumped my karma because two people got back to me today regarding my liner issues - one fella who can machine a kawasaki liner to fit in, and a wrecker with a complete set of jugs, with pistons, lower kms than mine is anyhow, both same price $200 one way $200 the other way. I am going to get the 2nd hand items for now, and keep my busted one as plan b (plan b consists of finding some liners to fit in that will let me use some larger pistons )
    will get her running sweet for now, fix any tranny issues and then pursue increased capacity a little later on, for now im just craving a ride that ends with me switching the bike off, not the bike switching off on me!
    One step at a time however, i still need to pull the crank out to be able to re-fit the new bearings, big end cap and rod. Its all just nuts, bolts, time and money...
    Leave a comment:
  • b.walker5
    replied
    Thanks for that ken, i read something similar today. I will tell wife to go shopping and pull the racks out of out oven see if i cant get the offending sleeve out. otherwise i will run a bead of weld around the inside and try tapping it out then, works on bearing shells, should work for sleeves
    Whaat... Tell her to harden up man. John Britten just about built an entire engine in his wifes oven and did she complain ???? Well.... she probably did but no one would have listened. Some things are just more important eh.
    Leave a comment:
  • essjay
    replied
    Leave a comment:
  • Ken Talbot
    replied
    B-B-B-B-BREAKTHROUGH.
    I will speak to my local machine shop in the morning (yes its night here) and see about machining it out and pressing in a liner, ..
    One of the guys posted a while back about putting a bank of cylinders in an over (for powdercoating, I believe), and the oven heat was enough to make the sleeves fall right out. No need to machine them out and press in new.
    Leave a comment:
  • essjay
    replied
    Spoke to e few places today, i can buy new original liners for $169 aussie EACH, or a local engineering shop will take a look at my sample when i take it out, thinks it should be about $150 for the first one, and then around $30 for each one after that. Oh, and three weeks wait for the original ones, i think they are being made new anyhow. Anyone in Perth, Western Australia want some new liners for their bike?! would be a bargain of a group buy if only i didnt live in the middle of nowhere...
    Leave a comment:
    replied
    Well, at least he tipped you off that he was "insane"!! I've seen worse, much worse. Even picked one up that was much worse and almost got it back to health.
    Leave a comment:
  • essjay
    replied
    feast your eyes on all the glory that is my xs1100 when i picked her up... Killer paint job no? Sleep easy, mostly back to black now, painting as i go while engine bits have me held up
    Leave a comment:
  • essjay
    replied
    check..... clutch plate...... alignment.
    thats me adding it to the ever expanding to do list on a bike that was meant to be cheap reliable transport... *sigh* yeah, cam timing wasnt even right when i got the rocker cover off. luckily close enough that the pistons and valves are all OK. dont think he would know to turn it over fully twice (720 degrees) by hand before trying to start, seems like the type to just go for the starter first.
    Post photos, thats next on my to-do list i think, yes, so you can marvel at the PO of this bike and his lack of mechanical aptitude.
    Leave a comment:
