Question about Piston Slap
    replied
    While I won't argue about what his sound is, I will say I have had two motors with piston slap. I just went out to the garage to see if I had any of the cylinders with the marks in them, but they are too rusted to see now. There was a definate mark there in the cylinder that was an outline of the shape of the bottom of the piston skirt. I've never had a loose wrist pin in any of them before, but Kat has! lol. I hear it's tough to push a bike up an off ramp?
    I did find one of the old pistons and just for grins mic'd it. Now this is in inches, but the piston above the top ring was still round at roughly 2.790". Measuring down below the oil ring on the skirt, I was expecting, with the grinding force of the piston on the wall, (The rod is at a pretty good angle and shoves the piston forward against the front cylinder wall as it goes up.. this is what eventually makes the cylinders egg-shaped) that the piston would be smaller front to back and wider on the sides. Turns out it's just the OPPOSITE!? I measured 2.810" front to back and 2.800" at the sides under the pin hole.
    Leave a comment:
  • Ivan
    replied
    In my experience what you describe is probably loose wrist pins. Not a big deal but annoying none the less. Almost sounds like a low end knock, but isn't in the low end. Most of the time piston slap comes from FOD (Foreign Object Damage) when someone is changing plugs and drops a screw or some other small object that gets lodged in the side of the piston, and eventually bounces out in the exhaust. The piston will cock sideways from the object not compressing and actually squishes the skirt in. Then every time the cylinder fires, the piston wobbles a bit. It sounds different to a trained ear, but unless you have run some gravel through your engine, I would likely say it isn't truly piston slap.
    Leave a comment:
    replied
    In the ones I've seen, any markings will be much more pronounced on the piston skirt since it's much softer than the steel of the cylinder. You will, however, be able to see a mark where it was slapping the cylinder in the same spot over and over... though it looks more like a discoloration than scoring. You'll need to MIC the cylinders front to back very carefully as they get elongated before trying to re-use them as well as the pistons and skirts.
    Leave a comment:
  • mack
    replied
    question
    not trying to hijack this thread but, if one was to look at the sleeves while the head is off, piston slap would score them and be quite evident wouldn't it. My head is off and that is something I hadn't looked for yet, but since my compression numbers were pretty low, this might be a good idea?
    Leave a comment:
    replied
    Hey Cy,
    Simple test, surprised someone didn't already suggest it! DISCONNECT The vacuum hose going to the advance unit, just plug it so you don't have a vacuum leak, and then ride it to see/hear if you hear the noise!
    If you don't, then you've discovered the cause of the noise, but if you still hear the noise, then it won't be the vac. adv. unit, and it could be piston slap?
    Your right, that's a good idea. I happen to have an extra rubber cap since I had to buy a set when I synced my carbs because the ones that were on there pretty much came apart when I removed them. They came in a package of like 4 or something so I have a few spares. I'll just pop one on the carb fitting and leave the hose hanging in there and give it a try as soon as things dry out here (commute is going fine, but I need to get it out on the road to see how it does).
    Maybe if the weather is decent on Sat I can do the test after I finish installing the new fork seals and front brake pads (I've had the pads sitting waiting till I fixed the leak before I install them).
    Leave a comment:
    replied
    Hey Cy,
    Leave a comment:
    replied
    Originally posted by Larrym
    Cy,
    For entertainment or enlightenment, you decide:
    Thing is that the camera is less than 3 inches from the left cover. At higher speeds the wind noise drowns out that clicking sound.
    Well, that sound is not at all like the sound I'm getting.
    Yes, the vacuum advance is connected to the correct port on #2 Carb. I had the cover off last night to adjust my CCT and the timing plate is spinning true without rubbing against the ignition pick-ups.
    I've checked that on mine also, and there is no wobble to it at all. Straight and true, the edges are crisp and clear at all speeds, both with and without the timing light involved.
    The noise is what one would hear if you had your face down there during a ride. The low rpms mean that the vacuum pulses from #2 carb aren't fast enough to smooth out the action of the vacuum advance. I'm sure it evens out at the higher rpms/speeds. I don't hear it all that much but then again I don't have a fairing which acts like an acoustical bell/reflector to make the sound appear louder as I ride. Makes me wonder if adding a dampener in the vacuum line might be a good idea after all.
    My vacuum advance bounces around just up off idle also. It does however smooth out as the throttle advances and RPM increases. My concern with adding a damper is that the ignition retard from quickly opening the throttle would be slower, and more likely to cause pinging. I'm thinking that the jitter at low RPM's may be what truly causes the problem with the wires, as the fast repeated vibrations like that can't be good for those wires.
    So I'd ask if the noise you hear appears to be louder on the left or right side of the bike as you're tooling down the road trying to stay between the lines. As far as that goes, I'd recommend extra caution if you decide to do a left/right side listening test while riding: moving your head/body to one side or the other of the centerline of the bike may inadvertently cause the bike to steer in that direction. We wouldn't want you or your nice ride to cross the centerline of the road and end up in a head-on collision.
    I have been trying to get an idea of where it's coming from, and best I can tell, it seems to be lower than the valve train, but higher than the crankshaft. It's hard to tell going down the road of course, but the directionality of the sound seems to be just slightly lower than the valve train noise. I've been wondering if I would even notice the noise without the fairing? I'm thinking about putting some sort of sound dampening material which I hope might help.
    Then at the very least we'd have an awkward pause in your posts here on the forum while you're on the mend in a hospital bed somewhere.
    It would be rather awkward for me as well.
    Leave a comment:
    replied
    Acoustic Anomalies??
    Cy,
    Leave a comment:
    replied
    Is there any way you could put it on the center stand, start it, put it in gear, then put a load on it for a little bit with the rear brake? You can take the left engine cover off when you do this and see if the vaccum mechanism is vibrating wildly.
    Another thing to watch for with that sidecover off is to see the timing plate spinning true. If the crank bearings are going bad, you can actually see it wobble a bit. I've had the timing plate mounted on the crank wobble enough to smear a couple sets of pickup coils. If it gets bad, it will start seeping oil out of that seal. It can't seal against that vibration.
    ANOTHER thing.. is to watch that the vaccum mechanism is actually moving. The bearing it rides on sometimes gets rusty and freezes up, not allowing it to have the right timing.. and the engine will get pre-detonation like the gas is bad.
    Leave a comment:
    replied
    Got the same knock on my 79SF. I got it to quiet down a lot by limiting the travel of the vac. advance unit to about half it's usual draw. My 79F doesn't make that noise at all. Make sure the vac. advance unit is not "wobbling" during operation.
    Leave a comment:
    replied
    Originally posted by BossMaverick
    I also have that annoying vacuum advance fairing combination thing going on. I wouldn't worry about it because as you said, it goes away if you hit the gas in that rpm range. Your oil use is fine and your not complaining of low power or anything so I think your fine.
    I would agree except it only gets quieter, it doesn't go away. I'm changing the engine anyways, because I got a nice engine that's already painted a nice black, and so far everything looks really good on it. I'm in the process of sanding an polishing the edges of the fins (don't want to polish them too much though as I intend to put HT clear on them to keep them from having to be polished all the time. I want it to look nice, but I want to ride, not polish it all the time.
    If this engine makes the same sound, I'll accept it as normal, but right now, I'm not sure. The TSB states that the knock is right around 4k, and this starts a lot lower. I'm not worried the engine is going to grenade on me, but I'm not feeling like I can trust it for almost 1000 miles for the California Rally this June. Maybe I should put a trailer hitch on and carry a spare engine just in case? Naw, I wouldn't want to try and change one out with only hand tools. My air tools make the job so much easier.
    I was really hoping that someone had some insight on how piston slap behaves on an air cooled engine. It would be nice if someone who knew what the TSB noise sounds like could ride Brutus and tell me for sure if it's the same sound, but there just don't seem to be any other members close enough (especially one who knows the sound). I would love to get a second opinion on it, but don't have a way to accurately capture the sound or have someone who knows these engines who can ride it and tell me what they think of the sound.
    Frankly I'm a bit jealous of the guys in the midwest (not of the short riding season though) as they have so much help close by. I know there are some really knowledgeable guys down south, and at least one over in Reno, but I don't think any of them are coming up or over this way any time soon so it limits my options. I'll have to see if I can figure out a way to mount my camera on the bike and get some video along with the audio and maybe I can capture the sound well enough for troubleshooting.
    Leave a comment:
    replied
    Originally posted by petejw
    you could try putting a stethoscope or screw
    driver next to the barrels and hear if the noise
    is coming from there or down near the sump
    to hear if its coming from the bearings. jat
    I'm not sure how I would do that since the only time the noise happens is under light to medium load from about 3 to 5 k. Even in first gear that's a little fast to be trying to get a stethoscope against it to hear.
    Leave a comment:
  • BossMaverick
    replied
    Leave a comment:
  • petejw
    replied
    Leave a comment:
    replied
    Yeah, at idle and the carbs needing synched, you can hear some primary chain. But under load you shouldn't.
    Leave a comment:
